08-11-2006, 10:57 AM | #1 |
Rock Stacker Join Date: Apr 2005 Location: waconia
| run time question
i was out driving my cralwer the other day after i put in a new hitech high torque servo and had some questions. First, i run stock clod motors with a tekin rebel 2 esc. I got like maby 5 mins of run time while out bashing. It was some rugged terrain where my tires would often get jammed in the rocks and lock up so im sure that had a little to do with it because of the stress on the motors. My question is, if i change to the lather motors (which i need to do anyway) will i see a heavy increase in run time? oh the bat was a 3300 nimh. |
08-11-2006, 12:55 PM | #2 |
RCC Addict Join Date: Jul 2006 Location: So Cal USA
When you install the lathe motors you should see 45min runtimes, some times even longer! Makes a big difference.
08-11-2006, 01:25 PM | #3 |
Pebble Pounder Join Date: Mar 2006 Location: Milan, IL QCA (rural)
No disrespect meant but the way you charge your 3300 nimh batteries is REALLY key also. The only reason I say that is because the silver can clod motors should still give better run time than that. I run my regular Clod with Saphire motors and a Super Rooster with smaller nicad batteries and get better run time than that.
08-11-2006, 01:25 PM | #4 |
Quarry Creeper Join Date: Feb 2005 Location: Wheeling
Switching to lathe motors will help out tremendously. You can also increase run time by using lower gearing. Any way you can reduce the load on the motors, the better run time you will receive. Even running smaller tires will help. I see 10 miniute difference in run time between 2.2 and stock clod tires.
08-11-2006, 01:35 PM | #5 | |
I run 12 cells with stock clod motors and 11/10 gearing. I only see around 13 minutes of run time using 3000mah batteries. | |
08-11-2006, 07:11 PM | #6 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
i still run stock gears and kyosho stock motors with moab xls and get about 7 or 8 minutes run time just got motor mounts and ordered some 8 tooths from a buddy of mine going to put them in next week should help alot. i still have the original clod from 1987. i have had it for about 12 years still does pretty good.
08-12-2006, 08:59 AM | #7 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
I'm running stock silver cans, EVX modded to single pack, 1100 RX pack for the servo, 645MG servo, Zombie Maxx's on offset Maximizer beadlocks with 3oz weight added to each front wheel with some el-cheap-o 3300's and I can get 45 mins at least if I run it near full out all the time and at least 2 hours of crawl time on a single pack... When we go for a good 4-6 hour bash day, I change my packs out no more than twice, usually only once...
08-12-2006, 10:56 AM | #8 |
Pebble Pounder Join Date: Jul 2006 Location: Reppin the Pimp Cane in...North Jersey
Some lathe motors and lower pinions, smaller tires, better charger or charging habbits. last but not least...stop binding up the tires as much. |
08-12-2006, 04:13 PM | #9 |
hehe yeah i was jsut curious. i think the abt i was using might be shot anyway. i was more jsut curious about the increase from to motors. tho for some reason i cant seem to find them in stock.
