Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Cheap upgrade for COMP based 2.2 Clod....
Old 08-26-2006, 11:47 AM   #61
TLTCrawlin's Avatar
How does it lock?
TLTCrawlin is offline   Reply With Quote
Old 08-26-2006, 01:27 PM   #62
Originally Posted by ClodCrawlin
How does it lock?
It doesn't. There is enough drag from the gears and motor to keep it mostly locked. On a 2.2 Clod it works great, but on a Super based Clod it might not work as well as it does on the 2.2
toyofast is offline   Reply With Quote
Old 08-27-2006, 08:36 PM   #63
How do you pull a brush out with a servo? I have never torn into a motor? Someone needs to do a write up on this for me. Also which is more important 4WS or front digs if you had a choice?
Old 08-27-2006, 08:40 PM   #64
Originally Posted by camel_rc
I installed this mod on my 2.2 TS clod and holy carp, I'm a believer.
All praise the Holy Fish!
Unholy is offline   Reply With Quote
Old 08-28-2006, 02:32 PM   #65
Yes, I said carp for a reason. It's an inside joke that goes a ways back, but it's funny to say anyway. All praise the Holy Fish!
camel_rc is offline   Reply With Quote
Old 08-28-2006, 07:50 PM   #66
show me how to lockout one wheel at a time now
clod booster is offline   Reply With Quote
Old 08-28-2006, 11:10 PM   #67
If your diff is locked you can't do one wheel at a time.
Johnson420 is offline   Reply With Quote
Old 08-29-2006, 12:20 AM   #68
why do u need to do that?
ive found locking both rears works better
camozuk is offline   Reply With Quote
Old 08-29-2006, 01:54 PM   #69
locking one rear would give you dig on one wheel so you have all the power going to the opposite wheel alowing you to turn tighter
Old 08-29-2006, 10:24 PM   #70
If I install a rear lock out kit on my NN Clod(Super based), And do the Dig upgrade, would it work well as the 2.2 based clods? Another question, Which set-up would be or is more effective in rc crawling, 4ws or the front dig set-up?
Thanks
Kev808 is offline   Reply With Quote
Old 09-01-2006, 10:17 AM   #71
Ok I'm a retard. I just went out to the shop and looked it over. I've got it now. I must have messed the short bus to school that day.
Old 09-01-2006, 11:21 AM   #72
Thanks
id go with both.
Old 09-01-2006, 11:24 AM   #73
dezfan's Avatar
Wouldn't he need a 4 channel radio to do that?
1. Front steer
2. ESC
3. Rear steer
4. Dig
dezfan is offline   Reply With Quote
Old 09-01-2006, 06:47 PM   #74
1. Front steer
2. ESC
3. Rear steer
4. Dig
Sounds right, But wouldn't a "dig" be more effective on a front wheel steering rig as supposed to a 4ws rig?
Old 09-01-2006, 06:51 PM   #75
dezfan's Avatar
Definitely.
Old 09-01-2006, 06:56 PM   #76
cartronicshn's Avatar
how about something small like a relay that cuts out the power to the rear motor through channel 4?
cartronicshn is offline   Reply With Quote
Old 09-02-2006, 01:54 PM   #77
that way ^^^^ you still have both steering channels and forward reverse, what do you guys think, i will see if i can get a relay for this mod.
Old 09-02-2006, 08:50 PM   #78
If you are going to a 4 channel than 2 esc's would be far mor effective than just killing the rear motor.
Kamikaze is offline   Reply With Quote
