Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Like Tree6Likes
Thread: KCs New Clod "Pounder"
Old 12-26-2012, 10:51 PM   #1
Default KCs New Clod "Pounder"
Hey guys started a new project....another member on rcmt (Ernie-KingKlod) had a custom set of chassis plates cut for a "pounder" style chassis and had an extra set he sold to me...I had 2 clod pounders in the past and I kept jumping in and out of the idea about doing another 1 at sum point....So I picked up a few things and Monday the plates came in. All I need now are electronics...gonna be 4WS and dual castle brushless, probably the SV3s 4600 or 5700. I got a set of Gmade XD piggyback shocks in 103mm for this truck and Clod tire and wheels with CPE wideners (Justins old set from the Gunslinger he never finished building lol). I ordered a nice package from Brett to take care of the links, braces, steering...etc, Gonna start building the shocks and axles this weekend
Kingclod27 is offline   Reply With Quote
Old 12-27-2012, 09:23 AM   #2
Default Re: KCs New Clod "Pounder"
Sweet and you have my attention on this build
rocpede is online now   Reply With Quote
Old 12-29-2012, 10:20 PM   #3
I got started on the axles...I had 2 pair of axles and I gutted them both out, kept all the good stuff..
The gears from one set of axles where greased up really good with sum thick black grease, but they did have bearings throughout. So I took all the bearings out and other metal pieces and cleaned them off. I had 2 brand new sets of gears in the parts box, so I will use those and keep the others as back ups after I clean all that grease off
After I cleaned everything off I sorted the parts, cleaned out the gearcases and started putting the axles back together....Got tired and stopped so Ill finish it up later tonight.
Old 12-30-2012, 11:17 PM   #4
Got sum more work done to the axles...New gears and grease and bearings added
Then I installed the Level3rc mounts..I also decided not to do 4WS and Im going to use a combination CPE rear lockout brace and link setup...its the same setup I used on my first clod pounder and it proved to be very strong.
Then got the knuckles installed with bearings and brand new stub shafts. I will have to do a little more work with the dremel but they feel good. Gonna work on the shocks next
Old 12-31-2012, 08:50 AM   #5
Great update KingClod27, I was looking at one of the pics and noticed that one of your axle braces was up side down.
Old 12-31-2012, 09:42 AM   #6
Yea I noticed when I did it..Ill fix it at sum point lol....waiting on my package from CPE so I can make sum more progress
Old 12-31-2012, 09:57 AM   #7
Internet Know it all
Szczerba's Avatar
Looks good so far. I'll be checking back in on this one.
Szczerba is offline   Reply With Quote
Old 12-31-2012, 02:39 PM   #8
Thanks guys...Im working on the shocks now, then Im gonna get the dremel out and touch up the steering knuckles and tubes to get steering clearance...
Old 12-31-2012, 05:07 PM   #9
I have a Q. to , what did you use to get the think black grease off.
Old 12-31-2012, 05:57 PM   #10
I actually just put new gears in...I still have to clean that black grease off
Old 01-04-2013, 07:56 PM   #11
Got a present from Brett so I was able to get sum more work done...also finished building the shocks. I used the 2 hole pistons and same 35wt oil. (the Kinex in the background was a Christmas present from my 4yr old neice lol)
Old 01-09-2013, 09:33 PM   #12
Got sum more work done....
got the vertical servo mount and links installed and the rear lockout I jacked from another project..The I got the axles, shocks and links mounted to the chassis and got closer to a "roller"...
Old 01-10-2013, 01:11 PM   #13
Baller
love clods, thats gona be a sick build
maddmatt11 is offline   Reply With Quote
Old 01-11-2013, 12:17 PM   #14
Gonna start tearing it back down so I can regrease the gears and replace sum screws and nuts. Also need to paint or powdercoat it. Then I can add the velcro for the body.
Old 01-21-2013, 10:21 AM   #15
Ok since its slow I mocked up the Clod to see how everything would sit before I tore it all down to do the final build...Got this body from Tom(TXT-2.0), thanks again..Its not the body that I will use on this chassis but I will run it as a back up..Going back to 4WS and painting the chassis..Here are a few pics as it sits now...
Old 02-11-2013, 07:46 AM   #16
Ok small update....few changes to the plan as other trucks and bodies have been shifted around...
The Clod is still going out for powdercoating but a different color now...Its getting a new body too..also put these Gmade shocks on the new TXT Pounder and ordered a softer set of Gmades for this truck. This truck will run the Castle 5700 SV2s that were in the Diablo, and the TXT wheels and Rumbles.. Both trucks are getting ready for the upcoming MT racing series here and for the No Limit World Finals this year at Diggers Dungeon...
* - No Limit RC Home of the RC Monster Truck World Finals
Old 02-11-2013, 09:31 PM   #17
Nice work, love the Bigfoot body!
Kingclod27 likes this.
MaTa is offline   Reply With Quote
Old 02-22-2013, 07:31 AM   #18
Got the new body for this truck and now sending the chassis out to be powdercoated...Once I get it back next week I can finally assemble it...I upgraded the axle tubes and knuckles to aluminum and Im using the old Steering setup, BTA and upper link mounts from my Diablo....Ill take a few pics when I get home.
Old 02-25-2013, 07:49 AM   #19
Got a chance to work on the truck a lil this weekend...After doing the drop test...and breaking a few thingsl, I ungraded to aluminum tubes (from the old Diablo) and new Integy knuckles..Also gonna see how the ZRP steering and lockout setup works..I flipped the BTA and used CPEs vertical servo mount...hopefully it works.
rjwalker and RcScott like this.
Old 03-11-2013, 09:16 AM   #20
Finally decided on a color lol...kept it simple and went with black. I sent the chassis off this weekend along with Kong shocks so hopefully ill have those back by this weekend or next week. Gonna heat shrink the links...I have 3 Bigfoot bodies I can use on this chassis too..
KCs New Clod "Pounder" - Similar Threads
BADDMANS C1 called 50Cal """XR10 up grade""" baddman 1.9 Scale Rigs 21 08-27-2012 11:56 PM
"Victim" or "V2" a "Country Boy Customs" class 3 Mighty1 2.2 Scale Rigs 10 05-06-2011 10:56 PM
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
