Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Oh Clod, why can't you steer?
Old 03-12-2013, 07:03 PM   #1
Default Oh Clod, why can't you steer?
I know, if you have a Clod you're going to have steering issues. But here we go anyway: I have a servo mount on the axle, and 2 inch spacers on the wheels (I know its big but its bad a@@), locked diff and rear steer locked out. I know im not doing myself any favors with this set up. So what im looking for is a servo mount that puts the servo infront of the gearbox, dead center. I have limited fabrication resources so making my own is difficult. Does anyone know of site that still sells one? All the sites I find list them but are discontinued. Or does anyone have blueprints on how to make one?
Thanks all
1375 is offline   Reply With Quote
Old 03-12-2013, 07:13 PM   #2
Default Re: Oh Clod, why can't you steer?
First one that comes to mind is Thundertech, but they are no longer available. Clodbuster Servo mount
scorpiondave is offline   Reply With Quote
Old 03-12-2013, 08:34 PM   #3
looks like crawford perfomance has them.
Crawford Performance Engineering : CPE-VERTSTR: Clodbuster Vertical Servo Mount - $14.99
sosume is offline   Reply With Quote
Old 03-13-2013, 08:11 AM   #4
RMK
Did you modify the knuckles to allow for more steering? I've never had any issues with mounting the servo on the axle brace. Plus, when you mount it in front of the gearbox, its a lot more likely to get damaged.....
RMK is offline   Reply With Quote
Old 03-13-2013, 04:14 PM   #5
I trimmed the stops off to get the maximum swing. The mount I have is at the same angle as the brace. Would a mount that's flat be better?
Old 03-13-2013, 04:26 PM   #6
It's just a matter of which mount will work best for what setup you have.
Old 03-13-2013, 07:54 PM   #7
RMK
post some pics if you can. then we can see your steering and give better feedback. there are lay flat servo mounts, verticle servo mounts, brace mounts etc.....
Old 03-14-2013, 06:18 AM   #8
Servo mounts, check esp chassis, they still have them listed. I have dealt with them since 88 when I bought my 1st clod from him, and 4 chassis' since.
lanechange70 is offline   Reply With Quote
Old 03-15-2013, 07:36 AM   #9
Thanks all
I just re-read this. Is your front diff locked too?
If I'm reading that right, you have front and rear locked diffs, rear steer lockout, and wheel wideners?
I don't think there is much you can do besides cut the stops of the knuckles and get the highest torque servo possible.
Old 03-15-2013, 02:52 PM   #10
I agree with everyone else, with that setup your running, your gonna be limited on steering no matter wat you do...
Kingclod27 is offline   Reply With Quote
Old 03-16-2013, 10:16 AM   #11
can you post some pics? I may have what you need but not sure of the application. I just sold my last center, front of axle servo mount that was a copy of the TTR ones but I coud always make another
Monster Crawler is offline   Reply With Quote
Old 03-16-2013, 12:12 PM   #12
Sounds good. I'll try to post some pics today. I added some fwd toe-in and it seemed to (oddly) help.
Old 03-17-2013, 09:47 PM   #13
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Here's my current setup. Don't mind the sloppy wires I'm not 100% done. But that didn't stop me from taking it out today
Old 03-18-2013, 08:17 AM   #14
RMK
Nice rig! It is wide!!! looks good tho. Does the lower steering link hit the gearcase any at full steering lock? If it does, i would put some bends in it at the ends. That will fix that. As for the servo and tie rod.... I would flip your servo and put a shorter tie rod onto the other knuckle. That way you only have 1 long steering link to possibly flex. Toe out always helps turn in. If your front diff is locked, that will hurt steering. How wide it is, that hurts steering. If it has a really long wheelbase, that hurts steering.
Honestly, if it was my rig, I would make sure that the front has as much steering as possible and then add rear steer. Install a y-harness and you can keep your current radio. Remember, if your rear has the same throw as the front.... Your turning radius will be cut in half.... I hope any of this helps.
Old 03-18-2013, 01:22 PM   #15
Thanks for the advice. After running it yesterday I know im going to get a longer servo horn then just tweak till is right. But what a fun rig to run
Oh Clod, why can't you steer? - Similar Threads
some questions (2 escs;rear steer; clod stall) spawnconnery Newbie General 6 09-08-2009 08:03 PM
E-Fly 6Ch Flight System/Can this be modded to use with Clod Crawler 4W steer and dig? TheHeadHunter Electronics 5 05-31-2008 03:50 AM
How do I cut the steer stops on the Clod knuckles? TheHeadHunter Tamiya Clod Buster 10 03-11-2008 06:09 PM
Hydro steer Clod? twisted77 Tamiya Clod Buster 11 05-11-2007 09:52 PM
