04-27-2013, 11:07 AM | #1 |
Pebble Pounder Join Date: Apr 2012 Location: springfield
| wheels don't turn when not moving
Is it normal to have the tires not turn when the clod is not moving? I have a 300oz servo and its mounted on the axle supports. I also have two batteries on my rig so its a little heavy. I'm running the servos off the exv2, so maybe they aren't getting the power they need? Also I noticed that when running the rear steers more than the front. I reversed the motors and the same thing happened to the previously rear servo. Is this normal? This is a 4 link crawler chassis if that makes a difference. Thanks all |
04-27-2013, 11:15 AM | #2 |
| Re: wheels don't turn when not moving
Ever drive a car without power steering? Harder to turn the wheel when not moving, yeah? But if you had more muscle in your arms it might not be so hard... I use a HiTec 7950 in my 2.2 tire truck, and it has 403 ounces of torque at 6 volts input. As for the ears turning more than the fronts, the same thing will happen while driving in reverse. It's a push versus pull thing. |
04-27-2013, 11:25 AM | #3 |
Good. My first clod so I'm still getting used to what's normal. Thanks for help
wheels don't turn when not moving - Similar Threads | ||||
Front wheels won't turn! | growlinsax | Axial Wraith | 13 | 08-07-2012 11:43 PM |
Wheels wont turn? | pajey | Redcat Crawlers | 4 | 08-06-2012 10:18 PM |
More power and faster moving forward than moving backwards? | StickyWheels | Losi Micro-Rock Crawler | 8 | 01-07-2012 09:11 PM |
Wheels still moving in dig.... | procraft98 | RC4WD Bully | 9 | 02-27-2010 01:35 AM |
