10-07-2006, 10:42 AM | #21 | |
Ultimate RC Decals Join Date: Aug 2005 Location: San Antonio
thanks.. i give all the credit to d.i.l.l.i.g.a.f. for that one. | |
10-08-2006, 12:14 PM | #22 |
Rock Stacker Join Date: Sep 2006 Location: vancouver
i was thinking of that yesterday but i just used brake cleaner and re oiled the bearings
10-08-2006, 03:44 PM | #23 |
I wanna be Dave Join Date: May 2006 Location: akron
well I know you already did your waterproofing but I have to give my vote to the condom you dont have do stretch the opening like a ballon the dont seem to dry rought in my expeirence and they are lubed so they repeal water ok I maid that last part up nut it sounded good. |
11-18-2006, 07:45 PM | #24 |
Rock Crawler Join Date: Apr 2006 Location: louisville
condoms have that lube in them and on the outside im sure its not good on anything
11-18-2006, 10:43 PM | #25 |
Newbie Join Date: Aug 2006 Location: Spokane
Conformal coating maybe what he was thinking of. We used to use it when pelt cooling a CPU for overclocking. The Pelt would cause sever condensation in the CPU socket so it needed water proofing. It comes in many forms from dipping to spray. http://www.procooling.com/index.php?...s&disp=44&pg=1 |
11-18-2006, 10:53 PM | #26 | |
Rock Stacker Join Date: Aug 2006 Location: Cedar Park, TX
11-19-2006, 06:08 PM | #27 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
why would you shrink wrap you wires that already have rubber coating all over them?
11-21-2006, 08:12 PM | #28 |
Pebble Pounder Join Date: May 2006 Location: Abington
what about the axles though. if you have bearings won't they rust or at least stop rolling smoothly? or do most people keep the stock bushings for underwater use?
11-25-2006, 07:01 PM | #29 |
Pebble Pounder Join Date: Aug 2006 Location: Emporia
I was wondering what to do about the on off switch, if I put it in the balloon wont it be a pain in the butt to find each time?
11-25-2006, 10:09 PM | #30 |
Newbie Join Date: Oct 2006 Location: Claremore
| Make sure you pack the axles with plenty of grease. Water wont stay were grease is! As a precaution, I would pack a little dielectric grease in the servos to. Both the gear and the electronic side. Also oil the wheel bearings. Other than that, it sounds like you already have everything else figured out. Cant wait to get my truck back together so I can go swimming too! |
12-16-2006, 05:01 PM | #31 |
Rock Crawler Join Date: Aug 2006 Location: On the trail
can i put mi hitec hs 645 mg in water a mean is this servo waterproof?? thanks |
12-16-2006, 05:31 PM | #32 |
RCC Addict Join Date: Sep 2005 Location: Behind the torch!
Here's a few ideas from some boat guys: http://www.offshoreelectrics.com/MainPage.htm, just click on "tips & info" Some of them were already mentioned, but there's still some usefull info.
