![]() | #1 |
Got gang of parts in bins and boxes from Eddie at Crawler Innovations. He said make 3-4 rigs out of all these parts. This is not all the parts by any means! Goal is to make a roller to preserve the nostaliga of the r/c crawler for that time period. Most of these parts are from 2009. Here is the first rig from the piles. MiniClod Kit Quicksand/Grizzly4x4 Miniclod Axle kits MiniClod lets you run AX10 C-Hubs, Knuckles, lockouts and axle shafts. Reign Widemouth Chassis (mine I had laying around) but we dug around the parts pile and found another widemouth. DMG C-10 Truckee Topper VP Beadlocks Some 5.65" Cougars I built years ago with Crawler Innovation's Single stage Firm foams. Some parts are mock up some are final. Last edited by Szczerba; 08-08-2013 at 03:35 PM. |
![]() | #2 |
Axles. All plastic gears now. CPE upper links. Drilled a lower 3rd hole. ![]() ![]() Rear axle shafts shaved off to fit in MiniClod kit locker ![]() ![]() Sent from my thumbs. |
![]() | #3 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
Looking forward to your mini clod build. I used to own that DMG topper and c10 body very briefly years ago. Glad to see it again.
![]() | #4 |
Tire&Foam Extraordinaire ![]() Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
Thank you for building this rig for posterity Shane. ![]() If you have a build thread, pictures, or any links, please post them. I'd like to document as many parts as possible. With the fast movement of the 2.2 Pro comp market, everything shifted and many unique parts were kinda skipped over. |
![]() | #5 |
Gold Star Baby Momma! ![]() Join Date: Feb 2004 Location: Maumelle, Ar
Funny how old school is cool again. My most coveted rig right now is a cherry super clod. I won't even let the little ones run it. I enjoy running it even as bad as it handles!
![]() | #6 | |||
| ![]() Quote:
![]() | #7 |
Rollerish ![]() ![]() ![]() ![]() ![]() ![]() Sent from my thumbs. |
![]() | #8 |
Rollerish ![]() Sent from my thumbs. |
![]() | #9 |
I have the mini clod kit also. It be interesting to see how you set up the steering. It was one of the most frustrating aspect of my built until I went with the pimp cane and went with bta steering.
![]() | #10 |
I bet there is a decased spektrum receiver in that toolbox. ![]() Super stoked to see those parts being used. I know it's supposed to be a shelf rig but I would still consider adding castor in case it gets ran. You can clock the tubes if you can't lay the motor down with the chassis setup. Is that like 50/50 droop sprung? |
![]() | #11 | ||
| ![]() Quote:
It's all in mockup still. Just wanted to figure out the links/wb right off the bat. I saw where some had re-drilled the tube flanges for clocking but not sure I wanna do that. Tons of motor clearance so I think I can do it with upper link adjustments. 4.25" or so shocks. Springs are just mockup for ride height. It is pretty much a half droop/sprung setup. These shocks are butter smooth so it feels good how it is, right now anyways. | ||
![]() | #12 |
That your 2.2p rig for nats? ![]() |
![]() | #13 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
This is a very very sweet rig.
![]() | #14 |
| ![]() Sure. Donate the electronics and I'll drive it. Thanks. I never owned a Mini Clod kit but it's a cool setup. Got the wheelbase right at 12.5" with 8/32" all thread and revos and worked on the steering a bit. Will get replaced with Ti links. Used an old RC4WD servo mount I had in my parts bin. Straight tie rod will need to get replaced with a more wavy setup. Vanquish Zero Ackerman knuckles installed. This is all mocked up and semi-final. ![]() ![]() ![]() ![]() ![]() Sent from my thumbs. |
![]() | #15 |
That looks like its going work well.What size are them tires?
![]() | #16 |
![]() | #17 |
Titanium links?!?! Where is the brake line or CF arrow links?
![]() | #18 |
![]() | #19 |
I wanna be Dave ![]() Join Date: Feb 2005 Location: Burnsville
Love it!! Reminds me of my 2.2 clod back when TLT's ruled the growing 2.2 class. Gotta have a Dig Switch with a tiny Blue Bird servo!! |
![]() | #20 | |
| ![]() Quote:
If this rig gets electronics it will Probably be a single BR-XL with two Holmes Hobbies 35turns. But the Manly dig switch is on reserve! ![]() Sent from my thumbs. | |
Crawler Innovations "Top Shelf" Ultra 4 | Nova's Ark | 1.9 Scale Rigs | 100 | 06-01-2018 11:31 PM |
--- Crawler Innovations "White Lightning Wraith" --- | Nova's Ark | Axial Wraith | 143 | 02-16-2017 11:07 AM |
