02-23-2014, 04:31 PM | #1 |
Rock Stacker Join Date: Feb 2012 Location: in the shop
| ClodMods
Did a few up dates on my Clod. Converted to pin drive so I could interchange the wheels with the Bully Stik. I made a 8mm o.d. sleeve that fits over the Clod spline shaft, and drilled a 2.5 mm hole through the shaft & sleeve. Swapped out the 6x12mm hub bearings for 8x12mm bearings. Also made the axle tubes which incorporate the lower link and shock mounts. A combination upper link mount and upper servo mount. The lower servo mount uses the standard through hole on the diff housing. Converted the wheels to pin drive. |
02-26-2014, 11:49 AM | #2 |
| Re: ClodMods
That's a cool looking rig!
03-02-2014, 11:12 AM | #3 |
| Re: ClodMods
Did a few more changes. Switched from the Gmade 104mm shocks to HPI 117mm shocks for a little more travel. Bent the lower links for more tire clearance. Changed the center barrel on the 2.8 wheels and mounted a set of Pro-Line Giant Trac tires. |
