05-12-2014, 05:13 PM | #1 |
Newbie Join Date: Jan 2014 Location: Guyton
| bec question
Ok so my question is .. can I use two BECs one for each servo...im using the evx2 esc and dual lipos... Im not sure how to wire this up... As is now the truck jumps and jitters and jerks when I plug in the servos. ...im think there not getting enough power and draing the power from the esc...so makes the truck go crazy.. Servos are savox 208oz... Thanks guys |
05-12-2014, 09:17 PM | #2 |
Quarry Creeper Join Date: Dec 2013 Location: Pevely
| Re: bec question
I don't have the answer but I'll bet you can find it in the stickies in the electronics section. If not, maybe ask in that section and someone should be able to help.
06-01-2014, 06:49 AM | #3 |
Newbie Join Date: May 2014 Location: Sydney Australia
| Re: bec question
There should be no problem doing it. When I add a bec I just tap into the battery wires on the esc. or you could make a plug (adapter) that has the bec wired in and Have it between the connection. If you want I can post a pic. One bec should be enough though. What info do you have on your servos / esc |
bec question - Similar Threads | ||||
Bec question | briang | Electronics | 4 | 01-25-2013 06:57 PM |
Bec question???? | bigdaddy13 | Newbie General | 5 | 06-11-2010 08:19 PM |
BEC Question | MSUCrawler | Newbie General | 3 | 03-03-2010 04:07 PM |
bec question | redking | Kyosho Crawlers | 7 | 05-03-2009 12:06 PM |
BEC question | Nish | Electronics | 7 | 03-10-2009 07:47 PM |
