11-13-2006, 02:11 PM | #1 |
Pebble Pounder Join Date: Apr 2006 Location: Cascade, Colorado
| My first try on a chassis
i made the chassis my self. what yall think? and just a little info on my other money pit |
11-13-2006, 03:13 PM | #2 |
nice. move your lower axle links to the top side of the axle for more clearance. i also had a 01 blue raptor.... is the front driverside link bent? |
11-13-2006, 03:20 PM | #3 |
You have some major axle steer problems.
11-13-2006, 04:07 PM | #4 |
yea the link is bent, it was like that from the last chassis (thats how i bought it). yea i have some axel steer problems, how could that be fixed?
11-13-2006, 06:23 PM | #5 |
Built, not bought Join Date: Oct 2004 Location: Gresham
If I'm correct,move your mounting points at the backbone closer to to it.As they are,they are spread too far apart.Other than that,good start.
11-13-2006, 06:44 PM | #6 |
Pebble Pounder Join Date: Mar 2006 Location: Asheville,NC
yea i have some axel steer problems, how could that be fixed? Your backbone is swiveling side to side of the mounting bolt that is holding to the axle. That is causing your links to push and pull on the axle ends causing axle steer. Try welding or epoxying the nuts into the end of the tubing. Looks like a great start. |
11-13-2006, 06:48 PM | #7 |
Mount the links closer to the backbone. You can try it out by using zip ties. |
11-13-2006, 10:28 PM | #8 |
so how can i clear the motor and still move the links in? thanks |
11-14-2006, 02:28 PM | #9 |
nothing else? ok.
11-14-2006, 03:49 PM | #10 | |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
11-14-2006, 05:57 PM | #11 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
IF anything move them in so you don't constantly get stuck on rocks here
11-14-2006, 06:20 PM | #12 |
thanks guys i'll hafta give that stuff a try plus i just got more goodies for it. thanks
11-14-2006, 10:18 PM | #13 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
Why not just go linkless ? then you will not have the problem of the links or link mounts getting cought on rocks . it will all but stop axle steer . you can make a single drop down bar and bolt it to the axle case like on my old homemade stick . here is some pics might help you . the rear drop down is a skid also to help the rear side over rocks . the Blue Chevy in this link Started new tuber build is the chassis in the pics . the Vette is also this type of chassis .
11-15-2006, 08:17 AM | #14 |
that was my second idea, i am gona try this one just bc i only have a mig welder, and a bunch of extera steel laying around. the pimp cane is next if i dont like this one
