12-02-2006, 04:38 PM | #41 |
Rock Crawler Join Date: Mar 2004 Location: Where it's wet
Love it. The cage looks badda$$ too. Im wondering how difficult it will be to operate in a comp situation.... eager to see it in aciton!
12-02-2006, 06:14 PM | #42 |
RCC Addict Join Date: Nov 2006 Location: southaven
that vid is bad a** |
12-02-2006, 08:51 PM | #43 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
Well I'm still going to finish it, with some removable lockouts just incase the rules change. Its still bas a$$ to drive without the rear servo.
12-02-2006, 09:47 PM | #44 |
Rock Crawler Join Date: Jan 2006 Location: In the basement
I love that setup. Are you bringing it to FOTO?
12-02-2006, 10:06 PM | #45 |
Colt Python/SR9c Join Date: Feb 2004 Location: out in the shop, reloading ammo!
Jeff, if your gonna come to the Hangover crawl(2.2 comp) @ Foto, make sure you are able to use it.. I wanna see what it can do |
12-02-2006, 11:56 PM | #46 |
[HOONIGAN] Join Date: Nov 2005 Location: Grand Junction
WOW, that is crazy. Really inovative and looks like it's going to work really well on the rocks. I can't wait to see a vid of it in action.
12-03-2006, 11:43 AM | #47 |
I'm gonna run it at FOTO on the 1st just like it sits, and after that till they tell me I can't.
12-03-2006, 04:46 PM | #49 |
Pebble Pounder Join Date: Mar 2006 Location: Asheville,NC
Awesome video. Your design really looks promising. Great idea.
12-03-2006, 05:09 PM | #50 |
I wanna be Dave Join Date: Jul 2005 Location: Cedar Rapids
That looked like it helped out a lot. How do you like the RR? |
12-03-2006, 07:46 PM | #51 | |
12-03-2006, 08:14 PM | #52 |
Well I guess the powers that be have pulled the plug on this build. So if anybody wants it you know were to find me.
12-03-2006, 08:24 PM | #53 | |
R.I.P. Chip Join Date: Jan 2004 Location: The Crawler State
Really??? I just went and looked at the votes for forced articulation, and there haven't yet been enough votes to call it yet. Not allowing forced articulation is leading by a far margin, but it isn't over yet. | |
12-03-2006, 08:25 PM | #54 |
Just going on what the grapevine has to say.
12-04-2006, 02:07 AM | #55 |
I wanna be Dave Join Date: Jun 2005 Location: KENNEWICK, WA
Why can't they make a class where anything gose 4WS, forced suspension, etc.? Make a couple classes, you don't see just 2 types of classes in 1:1. Cool rig man dont let the man get you down! |
12-04-2006, 08:26 AM | #56 | |
And it looks like forced artic would take quite a bit of skill to operate in a comp situation under pressure. Anyways, love the second vid too Great work man. | |
12-05-2006, 03:33 PM | #57 | |
Now the only thing I noticed but is fixable is I think I need some more foam in the rear red rocks just to keep them from smooshing up on an undercut ledge. The rubber is very close to as good as the mashers. Realy the only thing I would changes other that the rear foams is a little thicker carcass on the rr's. But since I am running clod axles the extra height far outweighed the small problems I incountered. With that said I climbed everything with the red rocks, I did'nt make everything with the mashers, mostly the near vertical ledges. There was a slight advantage in sidehilling with the mashers. So in conclusion I am going to run the red rocks, they fit my driving style and for me they work better, I just need to change the foams in the rear tires. I probably wouldn't run them on a tlt though, I think the extra weight helps them. | |
12-05-2006, 03:36 PM | #58 |
Try the Airsoft BBs, they work even better w/ a little more weight! |
12-05-2006, 03:38 PM | #59 |
Very cool write up thanks for the comparison. I watched a guy use them on a tlt. The biggest thing I noticed too was the side walls are very weak and fold too often. I don't know what foams or if any he had though. |
12-05-2006, 03:43 PM | #60 |
I noticed them folding up but thats fine for me with the dual esc's. I had it hanging on a leadge and the front tires were rapping almost to wear the rim would touch the rock, to me that tells me the tires are gripping.
