Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: 550 Motors on a modified Clod
Old 07-02-2014, 10:58 AM   #1
Default 550 Motors on a modified Clod
Does anyone run 550 motors with modified clods? I have seen some running the 7700 KV Castle systems, but I would think that a little more torque would be advantageous.
On the other hand, are motors like the Tekin 4800 KV SC4X too powerful for the drive train using stock gears? My ebay Purchase should arrive today, and I already have 2 Mamba Max Pros on the way. I also have a ton of motors, but no two are identical. My question is really which additional motor I should buy and whether I can run a 550 without issue. I am leaning to another 4000KV or 4800 KV Tekin since both are sensored, but I am sure the collective wisdom of the forum could outline the pros and cons of such a shoice.
I will likely run on 2S, although 3S is another possibility. The MT4G3 can handle all the speed I can throw at it and I only run it on 4S.
MeanTT is offline   Reply With Quote
Old 07-02-2014, 07:34 PM   #2
Default Re: 550 Motors on a modified Clod
I don't have any brushless experience but I know the traxxas titan 550's have been used. If you don't get an answer here then check out clodtalk, plenty of brushless builds over there.
chopfather is offline   Reply With Quote
Old 07-02-2014, 11:05 PM   #3
Thanks. For some reason I thought that the titans were actually shorter than the SC4X motors. I have a "550" 4 pole brushless rated at 4300 KV that's a China special and it is nearly the same length as a 540. It seems not all 550s are created equal. I'm still trying out how to mount my Castle 1415 2400kv motor in my modified ground pounder but I think it's just too long....
Old 07-03-2014, 09:06 PM   #4
There are a few cool ground pounder builds on clodtalk also. you should check it out.
Old 07-04-2014, 11:04 AM   #5
I have 4000kv setups in my Ripper on 2s. I love it. Loads of torque and it rips!
simon170 is offline   Reply With Quote
Old 07-10-2014, 07:07 PM   #6
Ever thought about getting a pair of Toro esc/brushless motor combos?
They're pretty cheap and comes with programing card.
Mudsy is offline   Reply With Quote
Old 07-14-2014, 10:51 AM   #7
I went with the MMP which I got a good deal on from Ebay, and the two SC4X motors I got are 4800 KV and I got them used off of Ebay, again for about 40 bucks per motor.
I wanted to stay away from 4 pole torque and also wanted sensored operation. The seller finally shipped the clod to me this weekend, 3 weeks after I paid him. I had to open up a fraud claim on his A$$ to get him to fulfil his obligations. What a pain.
Hopefully this works out okay. We will see. Thanks for the advice, much appreciated.
Old 07-18-2014, 03:15 PM   #8
Dealing with a similar shipping problem on eBay with the clod I bought a week ago. He printed the label but still has not dropped it off at ups.
rknaub is offline   Reply With Quote
Old 07-19-2014, 10:47 PM   #9
Well mine arrived! It has a Novak Super a Rooster and the two aforementioned brushed motors. I hope to fab the body mounts tomorrow for my pretty trick Proline Apocalypse body with the summit bumpers (and body mounts) extra lights for the roof, and of course the obligatory exo cage. Hope to have pics tomorrow of the aesthetics worked out.
It looks like the SC4X motors will fit, but just barely. After I get the mounts fabbed out of nylon, the electronics will come second. Then I will be overdue on fixing the suspension which is pretty much terrible...
550 Motors on a modified Clod - Similar Threads
550 motors 1of1547 Tamiya Clod Buster 6 04-10-2010 07:16 AM
16.8v with modified motors walker10r Electronics 1 03-31-2008 10:13 PM
Johnson 550 motors Mazlem Electronics 11 02-05-2005 02:45 PM
