11-26-2014, 04:37 PM | #21 |
Rock Stacker Join Date: Oct 2014 Location: Indiana
| Re: New guy with an old Clod |
12-10-2014, 05:42 PM | #22 |
12-10-2014, 05:56 PM | #23 |
Newbie Join Date: Sep 2006 Location: Waukesha
I've been super busy with overtime at work so my project isn't coming along as fast as I have wanted but this weekend I bought some Weld edition Pro Line beadlocks 40 series wheels used from a guy on Facebook. They should look huge with either Interco Swampers or Rock Rage tires. Were you thinking about changing your tire size?
12-10-2014, 07:28 PM | #24 |
I plan on going with 2.2" wheels and ProLine Super Swamper TSLs.
12-14-2014, 10:30 AM | #25 |
Ordered a couple Integy Matrix Pro 55T lathe motors yesterday.
12-29-2014, 05:32 PM | #26 |
I narrowed my wheels today. They went from 3 7/8" to 3 1/4". Now, the left front tire doesn't rub on the servo mount when it turns. Put the crew cab body on and mounted it 1" lower. I also opened up the new 55T Integy lathe motors after reading about poor build quality and out-of-round comms. I put the armatures in my lathe and took a clean-up cut to true the comms. They both only took .001-.002 to clean up. I must have lucked out and got a couple good motors. |
01-02-2015, 12:32 PM | #27 |
You are a really good machinist. How did you narrow the rims? Did you weld them and then cut them in a lathe? Great job. |
01-03-2015, 04:42 PM | #28 | |
| Re: New guy with an old Clod Quote:
I put them in my lathe and cut them just inside of the inner bead and then flipped the cut-off piece around and pressed it on. The larger ID at the bead luckily was a few thousandths smaller than the OD of the center of the wheels between the beads. | |
01-03-2015, 04:53 PM | #29 |
Got a little work done today. I mounted the battery holder over the front axle to move the weight forward. If I find it makes the truck too top heavy, I'll move it back to the lower center of the frame. Added spacers between the lower links and frame to gain more clearance between the lower shock mounts and the motors. At full flex I was afraid of the mounts shorting out against the endbells. |
06-14-2015, 07:48 PM | #30 |
I've decided to run 3S LiPo batteries so I ordered a low voltage alarm since my old-school Novak Super Rooster was made before the days of LiPo batteries. I also have a Futaba 3PL radio coming.
07-14-2015, 06:32 PM | #31 |
Got my Clod running again. I'm really liking the Futaba 3PL radio. It switches between 4WS and crab steer with a bump of the Dual-rate switch. The tires need glued so I can get to crawling. It's faster than I expected with the 55 turns on 3S. E7911FB8-FAA3-40C2-973D-49DF80EA0A27_zpszhl37mdl.mp4 Video by HoosierZ | Photobucket |
12-11-2015, 06:50 PM | #32 |
12-13-2015, 05:49 PM | #33 |
12-19-2015, 06:52 PM | #34 |
Put on the old body and did a little crawling in the garage today. Started painting the new body and should have it done tomorrow. Shot a short video. F31F47E8-C96C-4B79-BCA0-390AFB284FF5_zpsycdbdxig.mp4 Video by HoosierZ | Photobucket |
12-20-2015, 06:37 PM | #35 |
12-23-2015, 04:07 PM | #36 |
| Re: New guy with an old Clod Very nice, I would still run a thin bead of E6000 around inside the wheel so they stay together when you're bashing. Very nice Clod! |
12-23-2015, 08:04 PM | #37 |
12-25-2015, 08:40 PM | #38 |
01-01-2016, 09:17 AM | #39 |
01-02-2016, 08:23 AM | #40 |
New guy with an old Clod - Similar Threads | ||||
New guy guy here need helping choosing crawler | Qcustomz | Newbie General | 10 | 09-23-2012 10:27 AM |
guy in sarasota goes to e-wood goodwill and picks up a clod,jugg and rs4 for $9 | aftershock1 | Chit Chat | 17 | 02-17-2008 05:30 PM |
RC GUY Clod diff gear | JasonInAugusta | Axles, Trannys, T-case | 13 | 10-10-2005 12:50 PM |
