Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: New guy with an old Clod
Old 10-19-2014, 10:55 AM   #1
Default New guy with an old Clod
New guy here. My name's Adam and I recently dug out my old Clod and decided to build it into a crawler. I bought it about 16-18 years ago and messed around with it until I parked it about 5 yrs ago. I built a new chassis for it back around 2001 with CNC cut side plates and cantilever shocks with 3/16" Stainless links. I also made a set of aluminum wheels and grooved the stock tires for better flex. It currently has Trinity 17t motors but I plan on getting 55t crawler motors. The ESC is an old Novak Super Rooster. Servos are Hitec 645MGs.
HoosierClod is offline   Reply With Quote
Old 10-19-2014, 01:34 PM   #2
Default Re: New guy with an old Clod
That is a nice piece!
silvergagt04 is offline   Reply With Quote
Old 10-19-2014, 02:02 PM   #3
Thanks!
The R/C scene has changed a lot since I got out of it so I have a lot to learn.
Old 10-19-2014, 02:43 PM   #4
Same here, I got out about 6 years ago and got back in this summer and there are TONS of new things out now. I recommend picking up a couple RC magazines and reading them cover to cover. That is what I am doing.
Old 10-19-2014, 10:39 PM   #5
Nice clod! Clodtalk.com is a great resource for us junkies. Just built a clod crawler myself... Working on a basher now.
rknaub is offline   Reply With Quote
Old 10-19-2014, 11:46 PM   #6
That is a sick looking clod you have built. Looks more like a race clod. Then a crawler. Brings back memories of the old days, with all that flex.
Sent From My 2500 HD Tapatalk 2
rocpede is offline   Reply With Quote
Old 10-20-2014, 07:46 PM   #7
Thanks guys!
I did a little more grooving on the tires to make them more flexible and give them more lateral grip with more edges. Now, they kinda look like MT Baja Claws. I chucked them up in my lathe and used a grinding wheel in the Dremel.
Snapped a couple pics with the body off to show off the chassis.
Old 10-20-2014, 09:11 PM   #8
That is a cool way to groove tires. Wish I know someone that could, do that for me.
Old 10-20-2014, 09:19 PM   #9
Powered by Awesome
TwistedXT's Avatar
Lathe + tires = awesome
TwistedXT is offline   Reply With Quote
Old 10-23-2014, 12:16 PM   #10
Moderator
JatoTheRipper's Avatar
That is awesome! Nice work!
Old 10-26-2014, 08:31 AM   #11
I'm thinking of using the Proline Chevy HD short course body and Proline Super Swamper TSL XL 2.2" tires to give the Clod a semi-scale look.
Old 10-26-2014, 03:58 PM   #12
This is the look I'm after but with the larger short course body and wider Clod axles.
Old 10-31-2014, 03:36 PM   #13
Your Clod looks awesome. You have some awesome skills. Those tyres look factory! Chassis is a work of art. Keep the pics coming....
Sixtys Guy is offline   Reply With Quote
Old 11-04-2014, 03:48 PM   #14
Thanks guys.
I decided to do away with the cantilevers and link mount the shocks. That will open up the axle braces to give room to mount the steering servos and get the bumper off the front axle. It lost a little articulation but it still has 55*. The zip ties holding the shocks to the links are temporary. I'll machine something more permanent.
Old 11-04-2014, 04:17 PM   #15
Why did you decide to get rid of the cantilever setup? I am wondering because I was planning a sweet cantilever setup for mine. I was going to bearing mount them and everything but if there is a good reason not to go with that type of setup, I'd like to know it now. I don't want to waste a few hours at a Bridgeport and all the aluminum I would use. Thanks.
Old 11-04-2014, 05:05 PM   #16
I removed the cantilevers to make room on the axles to remount the servos on the axle braces. I also did it to shave weight and simplify things. It also should lower the COG a little by getting the shocks and cantilevers off the top of the chassis.
Old 11-04-2014, 06:56 PM   #17
I read that but I was thinking there was another reason besides. What are the travel of those shocks? I was thinking a 2:1 ratio on the cantilevers..
Old 11-04-2014, 07:30 PM   #18
The shocks are roughly 1" travel. The cantilevers are about 2.5:1 ratio.
Old 11-05-2014, 03:21 PM   #19
Made some lower shock mounts today. They are held in place with a set screw to allow adjustment on the links. I'll round the corners.
Old 11-09-2014, 04:57 PM   #20
Got a little done today. I used my soldering iron to plastic weld some cracks in the gearboxes around the upper link mounts. Time will tell if it works, but if it doesn't I'll buy new boxes. The servo is remounted on the axle brace. I plan on adding 4WS but I need new knuckles since I shaved the arms off when I went to 2WS. Threw on an old junk body and lowered it down since it has more clearance due to the truck now having less articulation.
New guy with an old Clod - Similar Threads
New guy guy here need helping choosing crawler Qcustomz Newbie General 10 09-23-2012 10:27 AM
guy in sarasota goes to e-wood goodwill and picks up a clod,jugg and rs4 for $9 aftershock1 Chit Chat 17 02-17-2008 05:30 PM
RC GUY Clod diff gear JasonInAugusta Axles, Trannys, T-case 13 10-10-2005 12:50 PM
