12-15-2006, 03:55 PM | #1 |
Newbie Join Date: Oct 2006 Location: Northern
| Robinson pinion question
Does any body still use robinson pinions like the ones at tower hobbies? If so how thick is your adjustable motor mount and how much tooth engagment is there left, also how much of the pinion is still on the stator shaft Thanks |
12-16-2006, 10:43 AM | #2 |
Anyone?:-(
12-16-2006, 11:28 AM | #3 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
RC4WD MM and the pinion engages the counter gear a little mor that half way, but I never had a problem with it, it still snaped axles before any gear damage occured.
12-16-2006, 02:30 PM | #4 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
i got a robinson 32p 10t on my tlt but i havnt ran it yet
12-16-2006, 02:37 PM | #5 |
Quarry Creeper Join Date: Oct 2006 Location: Simi Valley, CA
I runs Robinsons on my Revo, mini-t, TXT. I've never had a problem with them at all. They are great.
12-16-2006, 04:17 PM | #6 |
Cool, thanks guys. I think I will try the 9 and 10 tooth combo and see what happens. Do you guys actually have problems with twisting the stock axles? I plan on running 55t integeys if they ever get here. DUECE |
12-16-2006, 06:03 PM | #7 |
Pebble Pounder Join Date: Oct 2006 Location: Westbrook Park,Pa.
does robinson make the an 8t pinion for clod motor??? I also plan on running 55t integy Frank |
12-16-2006, 11:26 PM | #8 |
The smallest ones I have seen have been 9T.
12-17-2006, 01:40 AM | #9 |
I don't think Robinson makes any, but RC4WD has 6, 7 and 8 tooth pinions.
12-17-2006, 01:28 PM | #10 |
all i use is robinson 9T pinions
12-17-2006, 02:03 PM | #11 |
When you guys run a 9t and 10t combo do you notice any axle fighting issues on say big slick rock were all four tires have full traction or is the the wheel speed difference not that noticable?
12-17-2006, 05:26 PM | #12 |
Is 9t good to run or 8t on my clod with 55t integy. I'm sorry everyone I'm former nitro guy and now learning the electric stuff for my new crawler build. Thanks Frank |
12-17-2006, 07:18 PM | #13 |
A 9T should be fine.
12-17-2006, 08:10 PM | #14 |
Thanks....is there a big difference between the 8 and 9 Thanks Frank |
12-17-2006, 10:50 PM | #15 |
I think it's something like 4 or 5 revolutions. I run 65 turn in front and 75 turn in rear and can't really see any difference. It should be similar with pinions. DOESN'T stop clodstall like I had hoped.
12-18-2006, 06:44 AM | #16 | |
12-18-2006, 10:49 AM | #17 | |
12-18-2006, 01:59 PM | #18 |
Pebble Pounder Join Date: Nov 2006 Location: northampton
I've had robinson products on many diff cars and trucks and never had a problem with them as the others have said.
12-18-2006, 02:39 PM | #19 |
I guess I will just order up a set of 9t and a 10t so I can try both combos. Thanks for all the info guys. |
