12-15-2006, 08:26 PM | #1 |
Rock Crawler Join Date: Feb 2006 Location: sunny acres
| 1st tuber issues
Here's my first try at a crawler. Specs- JB'ed clod axles ( bought it 17 yrs. ago ) 65t lathes 8t pinons TTR axles G Made knuckle braces Integy piggyback shocks 645mg servos G Made upper link mounts 4/40 allthread sleeved with 3/16 and 1/4 tubing links 8.4v Integy pack Narrowed Axiom beadlock wheels Holey roller beadlock rings Moabs with Airsoft BB active foams 1/4 and 3/16 brakeline MIG welded frame Anyway I'm having a few problems so far. My front links hit the motor leads at full flex. The front of the chassis hits the steering servo. I should be able to fab a lower axle brace mount to clear it. I also screwed up the link mounts on the chassis. The upper link mounts are inboard of the lower link mounts which screws with my caster angles. I may fab new mounts but I'll have to make new links also. I'll probably do them out of solid aluminum this time as the chassis is getting pretty heavy. Hood should be arriving this week so I can address some of the clearance problems and check the fit. Any tips or advice would be appreciated thanks, Jeremy |
12-17-2006, 08:30 AM | #2 |
Rock Stacker Join Date: Aug 2004
Good job for your first tuber..Its all trial and error....nothing that cant be fixed with a deremel and more tubing...Did you start out with a design on paper or did you just "wing it" as you went? The toughest part is getting all the link and shock mounts correct... now ..get back to work..lol
12-17-2006, 10:06 AM | #3 | |
