12-26-2006, 11:18 PM | #1 |
I joined the Band! Join Date: Dec 2006 Location: RENO
| Rc4wd Gear Reduction Problems
I Have Tested My New Super Rig And 5 Out Of 6 Times My 2.2/1 Reductions Have Come Apart. I Have Never Been Able To Fully Tighten Them Down Without It Binding The Bearings On The Shaft. Also All Three Pinions Come Loose Within 10-15 Minutes Both Front And Rear. I Have Used Thread Lock To No Avail. Are These Things Junk Or Is It Me. |
12-26-2006, 11:59 PM | #2 |
I wanna be Dave Join Date: Sep 2004 Location: SF Bay Area
Can you send us some pictures to rcrock(at)gmail.com and let us also know your order #. So we can take a look and see what cause the problem. thanks
12-27-2006, 12:08 AM | #3 |
I Will Do That Tommarrow. You Guys Always Stand Behind Your Stuff. I Have A Friend Who Has Had Them For Over A Year Without Problems, So I Dont Get It?
12-27-2006, 12:40 AM | #4 |
Rock Crawler Join Date: Jan 2005 Location: Nanakuli
i had the same problems there is a small 1/4" spacer that comes in the kit grind it down (a little at a time) until you get the screws at tight as possible. don't grind to much only until the two housings become flush when tightened to much and crack the housing. hope this helps just trying to make your job easier mike (rcwd) Last edited by kaaina; 12-27-2006 at 12:43 AM. |
12-27-2006, 08:47 AM | #5 |
I Did This. It Helps, But It Didnt Fix It. I Was Afraid To Take It Down To Much.
12-27-2006, 09:03 AM | #6 |
just keep going alittle at a time. i know when i did mine it ended up really thin but it solved the problem |
12-28-2006, 08:05 AM | #7 |
Rock Crawler Join Date: Apr 2006 Location: louisville
dont worry rc4wd will take care of you they always have for me
12-31-2006, 09:37 PM | #8 |
Quarry Creeper Join Date: Dec 2006 Location: Acworth
Sounds like you got a bad set. Mine work great.
01-07-2007, 03:19 PM | #9 |
Newbie Join Date: Aug 2005 Location: Ghent
my 2:1 gear reduction does the same thing, I have to leave them a little bit loose or they bind.
01-07-2007, 03:21 PM | #10 |
Anybody who has problem, make sure email us. We plan to make some minor changes to the design and material, but it wont happen until 2-3 weeks from now. |
