01-02-2007, 12:45 AM | #21 | |
Rock Stacker Join Date: Dec 2006 Location: USA
01-02-2007, 01:40 AM | #22 | |
Quarry Creeper Join Date: Aug 2004 Location: North Las Vegas
01-02-2007, 02:05 AM | #23 |
Rock Stacker Join Date: Nov 2006 Location: us
Deans are great just gotta be good and quick at soldering them. I use a little bit of associated's black grease so theyre alot easier to pull apart. |
01-02-2007, 09:19 AM | #24 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
I used to use powerpoles. At first I was crimping them, until I started having wires pull out. After that I soldered all of them. Then I found with some I had to super glue the pair together.... Some of them would be a very loose fit when slid together. And the biggest issue I had with them was when I started racing my Clod. Had a few times where the battery would just unplug after a jump.... Some powerpoles held great, others were very loose. Deans are very touchy, if you use to much heat you will melt the plastic and shift the pins. You can help avoid this by plugging two of them together when soldering. Also tin both the wires and plug, then solder them together. |
01-02-2007, 10:37 AM | #25 |
Quarry Creeper Join Date: Dec 2005 Location: United Kingdom
Following what Etype-R has mentioned, I am going to un-solder a pair of the connectors, put them together and resolder them. I will let you know what happens. I will do it on the tightest pair I can find. Looking on other threads that I searched regarding the deans been a tight connection, it appears that I am not the only person who has encountered problems with them. |
01-02-2007, 11:14 AM | #26 |
If you over heated them and moved the pins, I do not think you will have much luck in fixing them. I would just buy new ones and start over again.
01-02-2007, 11:49 AM | #27 | |
I wanna be Dave Join Date: Jan 2006 Location: Albuquerque
All my cheapo chinese knockoffs work perfectly for me. | |
01-02-2007, 12:06 PM | #28 |
Bit of an update. I de-soldered the wires from the deans connectors. I the put the connectors together and heated each metal tab. I then allowed them to cool. Once they had cooled I was then able to remove them without using pliers. I also sighted each tab with my eyes and gave a couple of them a little "tickle" with a pair of pliers. I will have to see what happens when I resolder the wires back on. I have to soldering irons that I can use. A 100 watt model and a 12 watt model. |
