01-27-2016, 12:29 PM | #1 |
Rock Stacker Join Date: Feb 2012 Location: in the shop
| Non splined axle?
Does anyone make a non-splined (at the wheel end) axle? So you could avoid using the Tamiya splined hex.
01-29-2016, 07:13 PM | #2 |
| Re: Non splined axle?
I guess not. I machined the splines off the stock axles, making it a 5mm shaft, then drilled for a 2mm drive pin.
01-29-2016, 08:28 PM | #3 |
Pebble Pounder Join Date: Dec 2013 Location: Canada
Thunder tech/mip made CVD that didn`t use the brass splined hex hub.But rc4wd makes XVD with metal hex hubs RC4WD Extreme Duty XVD for Clodbuster Axle |
01-30-2016, 12:46 PM | #4 |
I'm making a sprocket to fit the axle so I can mount snow tracks. Getting around the splined shaft makes it a lot easier.
Non splined axle? - Similar Threads | ||||
Splined Cs without splined housings | spidr | General Crawlers | 5 | 01-07-2014 07:08 PM |
