Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: my jugg buster
Old 01-31-2016, 04:41 PM   #1
Default my jugg buster
I got a juggernaught cab and a truggy type bed on a almost stock clod buster chassis I call it the jugg buster the back story I got a pile of rc stuff that had sat outside in the sun and rain for years there was a juggernaught complete and a ta02 s10 complete in the pile and a clod buster with the grave digger body on it after figuring out the jug just wasent it I started playing with the clod I added the jug cab and some toobe on the back and made a truggie like thing
ferp420 is offline   Reply With Quote
Old 01-31-2016, 04:49 PM   #2
Default Re: my jugg buster
It came with 2 twister motors that had 402 had written in marker on them a wp860 ESC the tires where roten so I added some team associated mt88 tires and wheels and used the old upper links off of my wraith on the top of the axle I also extended the wheel base by about 1.5" it dosent tip over so much any more I used the jb lockers front and rear in added some led lights and a fuel cell like deal I think its sweet and it craws good too
Old 01-31-2016, 05:02 PM   #3
Old 01-31-2016, 07:53 PM   #4
Old 02-01-2016, 08:27 AM   #5
Moderator
JatoTheRipper's Avatar
That's pretty cool! I wish they'd re-release the Jugg.
Old 03-02-2016, 08:25 AM   #6
The ESC went up in smoke the other day for no aperant reason I decided to replace both motors to just in case one was bad I picked up 2 goolrc 35t motors because they where real cheap and a 4s capable cheep Chinese speed controller we will see how this set up works out hopefully this set up holds for a while
Old 03-31-2016, 07:22 PM   #7
Where did you get the speed controller? Hobby King?
JeepFan is offline   Reply With Quote
Old 04-09-2016, 07:50 AM   #8
i hunt chin-e-bay for good deals sometimes ill buy something just because its so cheap if i think i might need it like esc and gear sets brushless motors body clips conectors
Old 05-15-2016, 08:19 AM   #9
I dig it, nice rescue!!!!
freddyg is offline   Reply With Quote
Old 06-17-2016, 01:11 PM   #10
thanks yo all the plastic is so britle the axles just about disintigrated so its time to replace the housings i am also reworking the front skid and servo mounts and shaving the stock lower links and reinforcing them with aluminum ill try to get some pictures up
Old 06-17-2016, 01:28 PM   #11
Old 08-01-2016, 10:48 AM   #12
I've finally got this thing running again I ended up using 2 new rain speed controllers one couldn't handle 2 motors on 3 s I cut the front skid way down and mounted the servo on the axle itself I have to weld a few tabs on to the skid and clean it up and it should be good the plastic I mounted the cab to went away so I replaced that area with some aluminum and now I have a really solid mount for the cab hinges to bolt to the motors were getting to hot for my liking so I ordered some 9t pinnions for it the thing flys right now so that should slow it down a bit and up the torque a bit I still have to build the new rear axle and shave and reinforce the rear links
Old 08-03-2016, 03:28 PM   #13
The pinnions showed up today I fit the front one and it fit perfect I did trim a little off the inside of the motor opening so the motor would fit I also made the last tab for the skid so I'll clean it up and weld it all together I'll change the rear pinnion when I build the new rear axle I am also thinking of redoing the rear toob work also or maybe just finish it as it is
Old 08-10-2016, 10:04 AM   #14
I got the rear axle built got the pinnions in its running really good I set the front ESC to f/b/r mode and the rear to f/r mode it eliminates the heavy drag brake on the front axle when going forward and becomes a drag break in reverse on the first click full reverse on second click all that's left is to clean it up and run it
Old 11-06-2016, 07:42 PM   #15
I installed a new set of shocks made a aluminum bed for the rear and after getting it all together the chassis cracked and one of the links snaped so its time for a bunch more new parts after all this rig has been through it deserves some new parts I might try to make some links out of aluminum but I want that stock lower link set up and i dont think i can replicate the stock links good enuff to look or work right its is still a clod after all and I want to keep it that way
Old 11-15-2016, 06:50 AM   #16
Question should i go with the red bullhead chassie or stick with the black chassie the red might give it a nice pop and its $6 cheaper but i have black now and i like it
Old 11-25-2016, 07:45 AM   #17
I went ahead and got the red chassis I figured I can always paint it if I don't like it and my new arms are here a!so I'll get a pic after I get it all together and rolling again
Old 11-29-2016, 08:27 PM   #18
Old 11-29-2016, 08:29 PM   #19
Old 11-29-2016, 08:30 PM   #20
my jugg buster - Similar Threads
My Jugg 1 and Jugg 2 restoration projects Warn Off Road Tamiya Txt-1 and Juggernaut 8 02-27-2014 04:22 PM
Jugg 2 value? JavelinSST390 Tamiya Txt-1 and Juggernaut 4 10-12-2012 07:46 AM
It's not a Clod Buster - It's the God Buster SINNER Tamiya Clod Buster 5 11-28-2006 07:08 AM
New Jugg Tuber rindaen Tamiya Txt-1 and Juggernaut 5 03-05-2006 09:37 PM
