01-07-2007, 07:20 PM | #1 |
Newbie Join Date: Dec 2006 Location: denver
| tell me what you think
this is my first try at building my own from the ground up i think its ok but what do you guys think ? http://i95.photobucket.com/albums/l1...8/IMG00057.jpg http://i95.photobucket.com/albums/l1...8/IMG00056.jpg http://i95.photobucket.com/albums/l1...8/IMG00055.jpg http://i95.photobucket.com/albums/l1...8/IMG00054.jpg |
01-07-2007, 07:23 PM | #2 |
Rock Crawler Join Date: Jun 2006 Location: huh?
Either shorten the wb or get a bigger body. Also try to limit down the flex |
01-07-2007, 07:57 PM | #3 |
Rock Crawler Join Date: Feb 2006 Location: Warner Robins
Looks good I'd also shorten the links and move the shocks closer down the link toward the axle. I ran the stock tires for a bit, no foams and they'll wrap around a rock check it:http://home.san.rr.com/cosmiccreeper I run the 1:6 nylint tires for fun/looks, but do my real crawling with proline giant tracs. Last edited by BrockGrimes; 01-07-2007 at 08:00 PM. |
01-07-2007, 07:57 PM | #4 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
lower it about 2.5" and run a wb in the 16'' to 17'' range. And get some new tires.
01-07-2007, 08:04 PM | #5 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
good starting point.. heres what your going to hear alot of lower the chassis limit the flex a little get different tires awsome start!!! |
01-07-2007, 08:31 PM | #6 |
RCC Addict Join Date: Sep 2005 Location: Lehi
lower it, and shorten the WB, then I think it will be pretty much set! |
01-08-2007, 12:09 AM | #7 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
needs to be lowered and new rubber when you can swing it but it looks ok to me! everyone keeps saying shorten the wb but I run right at 18" wb and 5.5" belly clearance and I love it! I have a few buddies that drive stick chassis's and I wear them out at every gtg we have! what is you wb at anyway? I would think anywhere from 16-18 would be good any more than 18 and you will start having major breakover angle problems!
01-08-2007, 03:05 AM | #8 |
w b is just under 18 and it has 6 inches under its belly this was my first try at making links
01-09-2007, 07:20 AM | #9 |
Quarry Creeper Join Date: Feb 2006 Location: Surrey B.C Canada
Brock said everything I had to suggest But I would get t-maxx addapters and run 40 series with moabs but thats just persanal prefrance Nice start though now just to dial it in |
01-09-2007, 03:25 PM | #10 | |
heres a pic for reference Last edited by bigflex; 01-09-2007 at 03:31 PM. | |
01-15-2007, 04:07 AM | #11 |
ok so i got every thing but my steering kit and had to play with it i set it where i wanted it to go did ok till i broke the front hub and axel tube i think it was cracked but now i know it is new ones on the way but i put a novak evx esc in it is that an ok one to use ?
01-15-2007, 10:58 AM | #12 |
Rock Crawler Join Date: May 2006 Location: Surrey, BC, Canada
EVX isn't bad... I run one in my Gecko... But I use an RX pack with it... The BEC on the EVX is kinda weaky even for a single servo.. It'll work one servo but it won't have full potential... I like full power to my servo... Without an RX pack, you can get decent runtimes, too, with it when yer crawlin'... I can go at least 45 mins to an hour on the EVX alone... Well over an hour with an RX pack... That's also with stock motors and RCGuy 8t pinions...
01-15-2007, 11:06 AM | #13 |
rx pack ???
01-15-2007, 11:47 AM | #14 | |
