01-19-2007, 07:08 PM | #1 |
Rock Crawler Join Date: May 2004 Location: delavan
| help
i am trying to build a torsion stick i have the aluminum c channel but how do i mount the gearboxes to the c channel pics would be great
01-19-2007, 07:26 PM | #2 |
You can buy Just the Mounts...Or better yet Just buy the whole Pimp Cane. The end results are always better. Many have tried to copy it, but very few have done a good job.
01-19-2007, 07:26 PM | #3 |
Quarry Creeper Join Date: May 2006 Location: Chandler
A little bit of ingenuity goes a long way.
01-19-2007, 07:29 PM | #4 |
Newbie Join Date: Feb 2005 Location: Peculiar
I just ground the sides of a 1/2 inch bolt down so it would fit inside the channel and then put that bolt through the hole where the original steeing was and put a nut on the bottom.
01-19-2007, 07:30 PM | #5 | |
01-19-2007, 07:30 PM | #6 | |
01-19-2007, 07:37 PM | #7 |
Yeah I failed to mention the links that I was runnin my bad.
01-19-2007, 08:45 PM | #8 |
i got it thanks i used some aluminum angle and cut it to fit around the motor mounting part of the gear box i also used a bolt to go through where the original steering was was simple once i got to tinkering with it
