01-26-2007, 05:28 PM | #1 |
Rock Stacker Join Date: Jan 2007 Location: netherlands
| 4 link length
hi i live in holland and there are not many crawler guys out here i am currently building a clod based crawler and a friend of mine designed a chassis for it my question is most of the guys here have shorter 4 links in front and longer in the back is this better or is the same lenght all around better i am still in the works so i can shorten them if needed thanks |
01-27-2007, 04:34 AM | #2 |
Rock Crawler Join Date: Apr 2006 Location: louisville
most run 50/50 or 60/40 weight balance the reason for longer links in the rear is to keep the weight on the front. if im wrong some one corect me
01-27-2007, 09:40 AM | #3 |
Newbie Join Date: Dec 2006 Location: Bentonville
Sounds right to me |
01-30-2007, 04:44 AM | #4 |
im going to try it with 50/50 set up later on i can change the lenght if i think it is neccesary thanks |
01-30-2007, 10:20 AM | #5 |
its easyer to shorten then to make longer. some people like long links some like short ones as long as you do a triangulated 4 link which means your top links are in a v shape youll be fine. what kinda rod ends are you gonna use
