04-23-2020, 01:27 PM | #1 |
Pebble Pounder Join Date: Jan 2020 Location: Northern Utah
| OG Clod Buster dilemma
I have my old Clod Buster with an aluminum cantalever chasis- 4 wheel steering and an old airtronics radio/receiver set up. It runs FAST but will hardly climb over my shoe, when it comes upon an obstacle I can hear the motors spinning, but no wheel movement. The turning radius is really bad(it was never a quick turner). What can (or should)I do to make this a better crawler. The motors run fast and the servos seem weak(?) Any ideas, suggestions or opinions greatly appreciated
04-23-2020, 03:26 PM | #2 |
| Re: OG Clod Buster dilemma
Wheels are most likely spinning inside the tires. A ~200oz/in or higher servo should help.
04-23-2020, 07:00 PM | #3 | |
| Re: OG Clod Buster dilemma Quote:
if you want to crawl you need locked diffs so take it apart and jb weld the differental gears solid also check for.broken and striped parts while you have the axle apart there is a servo on axle mount and linkage set your probably gona want 2 of those or just lock out the rear and get 1 set also dig is a option to help with turning for the motors your gona want smaller pinnions 12t should work and check to see if your tires are glued to the rims | |
04-23-2020, 07:05 PM | #4 |
Yeah you have to glue the tires to the wheels, but you also have to lock the diffs inside of the axles. Stock Clod Buster diffs are open.
OG Clod Buster dilemma - Similar Threads | ||||
It's not a Clod Buster - It's the God Buster | SINNER | Tamiya Clod Buster | 5 | 11-28-2006 07:08 AM |
a new clod buster | badtodabone | Chit Chat | 4 | 01-11-2006 06:31 AM |
