02-25-2007, 06:14 PM | #1 |
Newbie Join Date: Feb 2007 Location: Roseville
| Finally Done
Well after lurking in the shadows of this BB for quite some time I have actually finished my project. Well when I say finished I mean driveable, because I have a lot more to do. There are obvious things like body, finishing soldering the wiring etc... jb welded clod axles 55t motors LRP esc 40 series tires/wheels. homemade links Check it out and please give me some constructive criticism because this is my first crawler. |
02-25-2007, 06:51 PM | #2 |
move your steering tie rod to the top of the knuckle arms for more clearance. theres some thing off about the chassis setup too but i cant put my finger on it. looks too tall, and its lop sided or something, ill have to look at the pics more to figure it out |
02-25-2007, 07:38 PM | #3 |
Quarry Creeper Join Date: Oct 2006 Location: where fear and common sense don't get in the way
Like stang killa ss mentioned, move your links above the knuckles. Looks like you already bent the LH ball end in pic 4. Raising them up will give you more aproach clearance. Might want to re-examine the shock mounts also, looks like the fronts are too limited. Just my 2 bits.
02-25-2007, 07:45 PM | #4 |
I lost my vendor privileges Join Date: May 2006 Location: TOP OF THE HILL
right right. lookin good.
02-25-2007, 07:46 PM | #5 | |
FINALLY DONE ????? Rrrriiiiiiiiiiiiiiight You'll never be "done" | |
02-26-2007, 01:13 AM | #6 |
Rock Crawler Join Date: Apr 2006 Location: louisville
the servo arm get a metal one the plastic ones flex and break easy
02-26-2007, 11:22 AM | #7 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
Move the shock location on your chassis further up, to bring the shocks closer to vertical. You'll get less articulation, but the truck will feel more stable on the rocks.
02-26-2007, 05:13 PM | #8 |
thanks for the pointers, i will make the adjustments and post pics of phase 2. lol
02-26-2007, 06:25 PM | #9 |
Pebble Pounder Join Date: Feb 2007 Location: Monrovia
I woud make it 4ws also. It will help out alot. I would use a modded tq3 for a controller so you can run independent rear steer. or if you have a high end radio like my 3pk, you can use that too. i have mine so i can have front ws and normal 4ws and crab walk. its cool. |
02-26-2007, 06:31 PM | #10 |
Pebble Pounder Join Date: Feb 2007 Location: sunman
sweet
