03-01-2007, 08:07 PM | #1 |
Pebble Pounder Join Date: Feb 2007 Location: Monrovia
| Knuckle packs
Do you guys custom make the steering knuckle part to put the batts on, or can you buy them somewhere?
03-01-2007, 08:14 PM | #2 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
You can just zip tie/glue/tape the batteries to the stock knuckle or if you are using aluminum knuckles you can attach the batteries to a piece of PVC pipe and slide the pipe over the knuckles. Here's a link to the PVC version: sub c's on aluminum knuckles? |
03-01-2007, 09:32 PM | #3 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
If you don't have aluminum knuckles run2jeepn may have something for you soon...
03-02-2007, 11:07 PM | #4 |
I ended up just dremeling out the stock knuckles then ziptying and supergluing my batts into place. Worked out great, i have about an 1/8" clearance between my batts and wheels.
03-27-2007, 01:51 AM | #5 | |
Newbie Join Date: Jan 2007 Location: Rome
I am going to make my first knuckle pack..... Mario | |
03-28-2007, 02:58 AM | #6 |
I wanna be Dave Join Date: Sep 2005 Location: Dirty South
I run alum.. knuckles so I do the pvc pipe packs . I use 1" pipe and I use Black tape to build the knuckle up so the pipe will slip on tight . then I use 2 small screws to keep the packs from move in or out and getting it to my wheels . this is when I had stock hubs . It worked ok no problems ,other than the added weight seem to break more hubs out . Last edited by Badd; 03-28-2007 at 03:01 AM. |
03-28-2007, 01:59 PM | #7 |
Newbie Join Date: Oct 2006 Location: Florence - Italy
This is my way! It clips right on the alu knuckle, the one in the pic is by RC4WD, made on a cnc with polycarbonate (lexan). To don't make it spin and hold it in the desired position I use a screw directly on the knuckle. Sorry for the bad picture! |
03-29-2007, 07:20 AM | #8 |
VERY COOOOOL. Especially yours self-maden BADD. but Also the rc4wd.... Thank you. I will try.... |
03-29-2007, 09:58 AM | #9 |
Quarry Creeper Join Date: Jul 2006 Location: N. Phoenix
Here's what I'm doing,
03-29-2007, 11:16 AM | #10 |
Pebble Pounder Join Date: Jan 2006 Location: las vegas
VERY nice! looks great man!
03-29-2007, 12:21 PM | #11 |
Hey Link, where did you get those? did you make them yourself? What knuckles are those? I love that idea, they look real clean and nice.
03-29-2007, 12:26 PM | #12 |
Don't for get mine... 4 Sub-C's in a 3.2in wheel (Maxx) |
03-29-2007, 06:08 PM | #13 |
Yeah, but how much do they cost and when can i get a pair?
03-29-2007, 10:52 PM | #14 |
03-30-2007, 12:34 AM | #15 |
The only thing about mine is that you can easily change the batteries just removing the wheels without even removing the adapters or wideners. This way you can have multiple packs and charge them off the crawler. |
