03-07-2007, 01:02 AM | #1 |
Pebble Pounder Join Date: May 2006 Location: Chico, California
| adapter issue
I have a set of benders 12mm to 23mm adapters and only have enough threads left to screw the nut on about two turns. I now need to widen the stance so I need a set of widners that will work with the 12mm to 23mm adapters that will give my more threads or replace them with something. If I used 12mm to 12mm widners could I then put the adapters on after the widners. I really need some help with this because right now my tires are hitting my servo mounts. Any links to the widners that will work for me would be awesome, Thanks,
03-07-2007, 01:50 AM | #2 |
RCC Addict Join Date: Feb 2005 Location: Guam
try cpe mt's wideners. they should work. i have the same adapters with mine and will be ordering a set of his wideners i get alot of threads when i use just benders adapters though. got any pics?
03-07-2007, 03:19 AM | #3 |
Rock Crawler Join Date: Jan 2006 Location: Colorado Springs
You can try putting the TXT axle stubs in, they're a little bit longer than the clods so that should give you more threads to screw onto.
03-07-2007, 02:40 PM | #4 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
Get some barrel nuts, they should work.
