03-28-2007, 06:46 AM | #1 |
Rock Stacker Join Date: Mar 2005 Location: Louisville
| gear box emergency
so I have a bent inner axle, and I need to remove it. problem. I didn't realize that is is jb welded into the diff hex inside the gear box. I must have put it back together too soon. anybody know how to solve this problem with out tearing the gear box apart?
03-28-2007, 07:13 AM | #2 |
I wanna be Dave Join Date: Mar 2006 Location: One Legend.
There is an eclip on the inside of the axle shaft... How are you expecting to get it out without opening the gear case? It's really no big deal to open up... |
03-28-2007, 07:19 AM | #3 |
I got the gear case opened just enough to pop the e clip off, but I guess I was sloppy with the weld without knowing, and now it is all screwed up and stuck together. the last thing I want to do is buy a new complete gear case and axle. Has anyone ever tries simply green, and I read that someone had used gasoline. were these any good?
03-28-2007, 08:08 AM | #4 |
Web Wheeling Join Date: Jan 2005 Location: Twin Cities
the gearcase is cheap....
03-28-2007, 08:25 AM | #5 |
but how can I get the bent axle out of the inner hex? The splines have been jb welded on accident.
03-28-2007, 08:29 AM | #6 |
I wanna be Dave Join Date: May 2006 Location: Arlington, VA
replace the hex and be more careful with the JB weld next time. either way, if you had waited for the JB weld to fully cure then you probably wouldnt have been able to get the axle in the hex. if simple green does then JB weld is crap and if gas does then a buddy of mine has quite a few MC tanks coming back to him that he's patched with JB. |
03-28-2007, 08:52 AM | #7 |
| Finally
I was sitting at work and managed to pry the case apart with out damaging it. after a little elbow grease, I finally managed to get the axles and hexes out of the diff gear. only have one bent axle and two good spares at home. Hope this never happens again.
03-28-2007, 02:34 PM | #8 |
Newbie Join Date: Feb 2007 Location: Mt. Sterling
they arent that bad to do and no i dont
