04-01-2007, 08:29 PM | #1 |
Newbie Join Date: Jan 2007 Location: Talent
| Clod to Axial Wheel Adaptors
I would like to know if someone could tell me were I could get some wheel adapters for axial 40 wheels and some moab xl tires I just ordered them and im waiting for them to arrive. I plan to narrow the wheels to 2" but im not sure what wheel adapters to use. RCP crawlers shows 12-17mm adapters but there out of stock. Not sure what are the best adapters to use. Any info would help a lot thanks.
04-01-2007, 08:30 PM | #2 |
2006 2.2 National Champ Join Date: Dec 2004 Location: Big Bear Lake
I have a couple sets in stock right now, RCP will have them back in stock shortly too. |
04-01-2007, 08:37 PM | #3 |
Do the axail wheels come with 14mm adaptores ? Can you use 12- 14s
04-02-2007, 08:22 AM | #4 |
Rock Crawler Join Date: Apr 2006 Location: louisville
rc4wdstore.com has them and check our venders market gotmax the axial rims are a 17mm hex if you need a 12 to 14 check the venders market or the link in my sig
04-02-2007, 08:36 AM | #5 | |
You have Bender's and you have RC4WD's adapters....there are others out there, but just go with one of them and you'll be good to go. | |
04-02-2007, 08:37 AM | #6 | |
Rock Crawler Join Date: Jun 2006 Location: Oak Lawn, Illinois
04-02-2007, 10:01 AM | #7 |
RC4WD 12-17 adaptors are also wideners. Im running a rockbull 3 chassis. If I narrow my axial wheels to 2" should I need wideners???????
04-02-2007, 11:23 AM | #8 |
04-02-2007, 01:26 PM | #9 |
04-02-2007, 06:21 PM | #10 |
Built, not bought Join Date: Oct 2004 Location: Gresham
I also have some that are about the same as Benders except aluminum.It all depends on what you want.Most people want a shear point and mine won't give you it like Benders will.Just remember,something has to give.
04-02-2007, 06:44 PM | #11 |
Here ya go: Notice the back is cut out for a cross pin and not a splined attachment like the Clod shafts. These adapters work perfect if you want to put these wheels on say a Revo or T-Maxx Last edited by Offroader5; 04-02-2007 at 06:48 PM. |
04-02-2007, 08:49 PM | #12 |
Thanks guys & Offroader5 for the info. Do any of you know if you have to run wideners with narrowed Axail wheels. I would like to get some ordered before my tires and wheels show up. Thanks again
04-02-2007, 08:58 PM | #13 |
| Sweet, those will work great with integys new clod axle stubs with the pin hole in them
04-03-2007, 12:16 AM | #14 |
RCC Addict Join Date: Feb 2005 Location: Crawlifornia Uber Alles
| i don't run wideners on mine. with the narrowed axials, it's wide enough with plenty of room to make it through narrow gates at comps.
04-03-2007, 07:00 AM | #15 |
i made my own, just used the cross-pin adaptors that come with the wheels. used a dremel to make the hex recess Cost: $0 a year of comps later, and they've yet to fail. Last edited by BENDER; 04-03-2007 at 08:08 AM. |
04-03-2007, 07:05 AM | #16 |
Do you have any clearance problems with moab XL's??????
04-03-2007, 08:04 AM | #17 |
04-03-2007, 11:34 AM | #18 |
04-03-2007, 12:23 PM | #19 |
04-03-2007, 06:29 PM | #20 |
im sorry i was abit unclear. i meant 2006 comp season, and TXRCRCA had a late start (summer only) so you are correct wise sir |
