Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: AJ's Clod FINISHED w/pics 9.23.05 page2
Old 03-23-2005, 04:20 PM   #21
your post said:
" well i made a couple of chassis tonight"
so i corrected you
mike is offline   Reply With Quote
Old 03-23-2005, 04:46 PM   #22
Originally Posted by EeePee
Ever think of maybe putting the battery on it's side to get the center very narrow?
nope but thats a good idea
rckjeep is offline   Reply With Quote
Old 03-23-2005, 07:11 PM   #23
MODERATOR™
EeePee's Avatar
Once in every few years they come out. It made sense to me when I realized how often the width of the TXT hurts it.
Then along came the Stick...
EeePee is offline   Reply With Quote
Old 03-23-2005, 07:14 PM   #24
PapaGriz Yo
Grizzly4x4's Avatar
Lookin good rckjeep. Impressive job bending the center skidplate.
Grizzly4x4 is offline   Reply With Quote
Old 03-28-2005, 09:33 AM   #25
Well I had my nephew drive my Tuber LT on some rocks the other day and he seemed to like it. I hope he digs this Clod I'm building for him. I think I'm going to take the chassis and chop it down so it's not so tall. I think I'll take at least an inch out of it. That will narrow the frame rails nicely too. Then it's make some arrow links and build it.
Old 03-30-2005, 01:52 PM   #26
How far apart are the links at the chassis. I'm looking for the distance between upper & lowers. I'm trying to get an idea of how tall to make the chassis.
Old 06-02-2005, 08:38 AM   #27
heres the latest, whatcha all think?
Old 06-02-2005, 12:39 PM   #28
That Looks Good And What Is The Thickens Of The Sheet Of Alm. And Were Did U Get From.
rocpede is offline   Reply With Quote
Old 06-02-2005, 12:58 PM   #29
I think it's all 1/16". the local metal yard
Old 06-02-2005, 04:46 PM   #30
standing the battery up would raise the cg a little
chafey is offline   Reply With Quote
Old 06-02-2005, 04:51 PM   #31
Ya I don't quite get that. I'm laying it flat. I may end up doing some drop down brackets for the lower links but I"m not sure yet.
Old 06-02-2005, 05:55 PM   #32
MODERATOR™
EeePee's Avatar
Maybe he meant my post about the battery on it's side, to get a narrower center?
Old 06-02-2005, 06:13 PM   #33
Thank You For The Help Rckjeep
Old 09-23-2005, 04:22 PM   #34
well I need to make a few adjustments but here it is AJ's Clod. But I'll keep it till xmas. Heehee
Old 09-23-2005, 04:31 PM   #35
does haVING THE BOTTOM LINKS on that much of an angle affect handling?
Old 09-23-2005, 07:16 PM   #36
it shouldnt
nice rig. love it
ILoveRCRockCrawlin is offline   Reply With Quote
Old 09-23-2005, 07:47 PM   #37
...does the suspension work with the links that much different in length?
Nice job on the chassis too BTW
Gimbal is offline   Reply With Quote
Old 09-23-2005, 08:31 PM   #38
CSR
Sweet Clod, RckJeep!
I've seen full size rigs with basically the same geometry. Should work fine. The motors might rotate down slightly as the suspension compresses but that fine. Articulation won't be effected since the top link post stays centered as the axle twists. ;)
CSR is offline   Reply With Quote
Old 09-24-2005, 01:36 AM   #39
Thanks Guys!, I'm not sure how it'll work Clods are a pita to build because the links @ the axles are so far apart. I have to figure out a way to keep the arrow links together. They keep seperating. Maybe some green locktight. Then I'll get it wired up and play with it.
Old 09-24-2005, 06:52 AM   #40
i don't think that'll work.but i could be wrong.do a search for arrow links or cf links on this site,there was a thread on this not to long ago
SPEED_RACER is offline   Reply With Quote
