04-20-2007, 10:13 AM | #21 | |
Newbie Join Date: Apr 2007 Location: Mississauga Canada
the ones I saw on ebay where the fully machined pieces not the cast, personally I dont like cast pieces as they will tent to break A LOT easier then billet or fully machined pieces | |
04-20-2007, 10:14 AM | #22 |
04-20-2007, 10:16 AM | #23 |
04-20-2007, 10:17 AM | #24 |
Pebble Pounder Join Date: Nov 2006 Location: scarborough CANADA
i have the RC4wd axle tubes and knuckles on my crawler right now. If you come out to the meet on the 29th of april you can check them out in person. personally i love them they are really strong. |
04-20-2007, 10:21 AM | #25 | |
Second they switch because stock arms break with very little force, RPM's arms are made with fibers so they have a little more flex before they break. If you were to use aluminum you will be adding unwanted weight to a racing rig, and if you do hit the wall with aluminum arms, say good bye to your bulk heads and probably diffs and you could possibly bend the arms... Last edited by CanadaCrawler; 04-20-2007 at 10:23 AM. | |
04-20-2007, 10:27 AM | #26 |
| I am talking about the big open space behind the brass hex hub, with out the stock cover that will get filled with dirt and mud and such...
04-20-2007, 10:30 AM | #27 |
Ok, I give up...in the end you'll buy what ya want...I was just tryin to give ya some more info to make an educated decision. I'm not going to go around pimping what I do for a living to prove anything...so I digress. Good luck on what ever you decide on |
04-20-2007, 10:32 AM | #28 |
I wanna be Dave Join Date: Apr 2006 Location: FLAGSTAFF
04-20-2007, 10:37 AM | #29 |
hmmm I dont know, it shows up on my computer
04-20-2007, 10:44 AM | #30 |
Rock Stacker Join Date: Feb 2007 Location: Bolingbrook
Pic does not show for me either (IE7 browser).....but I do know what hole you're talking about...ugly |
04-20-2007, 11:02 AM | #31 |
04-20-2007, 11:04 AM | #32 |
sorry it was on another forum so you probably had to log in to see it so I reposted it here: Last edited by CanadaCrawler; 04-20-2007 at 11:10 AM. |
04-20-2007, 11:16 AM | #33 | |
Here is how it looks with the aluminum one's...see how there's no big void now: http://img.photobucket.com/albums/v1...g?t=1177089718 | |
04-20-2007, 11:24 AM | #34 |
Right now I am liking the raptor axle because it is cheap and comes with all of this:
04-20-2007, 11:39 AM | #35 | |
Pebble Pounder Join Date: Mar 2007 Location: Merritt Island
Wait a bit longer and see if you like the Raptor 2 better, it'll allow you to go with BTA steering so you can reduce your clearance that much more (and scratch up those beautiful new Aluminum axles!). Plus, from what I have read, they may be letting you use CVDs in them, so you could strengthen them more by getting the Thundertech CVDs. That would at least leave you a little room to upgrade later if you need to. | |
04-20-2007, 11:43 AM | #36 |
those sound cool, do you know when they are coming out?
04-20-2007, 11:55 AM | #37 |
| Read up on them here: http://www.rccrawler.com/forum/showthread.php?t=67784. |
04-20-2007, 12:48 PM | #38 |
RCC Addict Join Date: Sep 2005 Location: Tempe, AZ
The things that keep me from getting Raptors are: no BTA steering no CVD only 30:1 gearing will not work with many brushless motors ie 3013 No good servo mounts a little wide No mount for ecu on axle They are sweet but...maybe the will address all these things with the Raptor2, we will see. I also don't see if the plastic axle tubes are reinforced at the knuckle area why go metal. |
04-20-2007, 12:55 PM | #39 |
I dont really like the raptor 2's, I am not sure how they would mount on my gecko 2. They dont have a brushless system for 2 motor rigs yet so I am not concerned about that, and my current rig is already setup with front axle steering with aluminum servo guards... so they should be able to pop right in... |
04-20-2007, 01:11 PM | #40 |
| I am running a mamba 25 Revolver set up now....two esc and two motors. and I know people running two mamba maxes with 3013's. So not sure what you mean by that but whatever you want. All that stuff in the front of the axle really cuts down on approach angle too.
