![]() | #21 |
ΜΟΛΩΝ ΛΑΒΕ ![]() Join Date: Dec 2006 Location: In tha Bush of Louisiana
the first problem was the upper 4 link mount it wouldn't stay in place there was clearance problems btw the susp. links and motor and don't get the steering setup from them it not that great either
![]() | #22 |
Are you modding the knucles (grinding them) or are you leaving them as they are with only one bearing?
![]() | #23 | |
I wanna be Dave Join Date: Jan 2004
| ![]() Quote:
These knuckles will be replaced with the JP Customs knuckles next week from RCP. The Integy ones may never see the rocks! ![]() | |
![]() | #24 |
Ok guys! Are you ready? Get your welding helmets on or at least some good sun glasses!!! |
![]() | #25 |
![]() | #26 |
![]() | #27 |
sweet
![]() | #28 |
I hated to admit it too. I really dig it. The Hustler chassis is getting it's Yellow powder coating finish as we speak. I think yellow, witht he chrome will be sweeeeet! |
![]() | #29 |
Newbie Join Date: May 2007 Location: laCoS
sikie sik
![]() | #30 |
What about the panels? what color are you painting those? or is everything going yellow? can't wait to see the finished product.
![]() | #31 |
![]() | #32 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
You can name it "Twankle and Glisten" ![]() |
![]() | #33 |
You should probably buy a set of these to go with it, the company name is a little ironic. ![]() |
![]() | #34 | |
Rock Crawler Join Date: Jul 2006 Location: Olympia
| ![]() Quote:
The only problem I've had with the Raptors is gearing. There shouldn't be any problem with the 4 link setup, mine was flawless. I didn't buy there steering though, I went with my own to keep the CG lower. Looks like part of your steering issues could be cause you steer into the ground cause you tried to get clearance without clocking the Raptors. DIRK: Looking great, I built mine with the stock tubes. | |
![]() | #35 |
![]() | #36 |
Dirt Addict ![]() Join Date: Jan 2004 Location: Stumblin' thru the parking lot of an invisible 7-Eleven
Wow....those are bright :-) Jay |
![]() | #37 |
![]() | #38 |
![]() | #39 |
![]() | #40 |
MODERHATER™ ![]() Join Date: Nov 2005 Location: Colorado
HAHAHAHA! The bling machine w/ some yeller to it! With the weight of your axles metal gears might be a good idear. Although you can probably get by....... Those Traxxas ball ends are going to snap the weight of those axles too, I run bigger Jato ones and they snap pretty easily. Can't wait to see it on the rocks! BTW, You missed out this weekend |
