Go Back   RCCrawler Forums > RCCrawler Brand Specific Tech > Superclass Crawlers > Tamiya Clod Buster
Thread: Super Class Bling Comp Rig
Old 06-21-2007, 09:31 AM   #101
Originally Posted by krawlinCJ View Post
But in all seriousness, about how much more capable would the average hustler chassis be than the average gecko 2 chassis? By that I mean everything is the same except the 2 chassis.
I think they are both capable platforms. What I think it will boil down to is the way you can master the two different rigs. With the Hustler, there is all down travel and the opposite with the gecko. This will create different crawling characteristics with each. Adjustability is also key in any crawler...so the ability to do this for individual courses and driving styles is important. I have tried just about every chassis out there and they are all capable. It's how you fine tune them and drive them! However, I do think the Hustler is the best looking even though the guy that puts them together is as ugly as a tree root.
DirkDigler is offline   Reply With Quote
Old 06-21-2007, 11:58 AM   #102
......Thats fawked-up.
By the way cool looking rig, got a name for it yet?
Kev808 is offline   Reply With Quote
Old 06-21-2007, 01:35 PM   #103
Looks great Dirk, I cant wait to order the hustler myself...if they ever come back instock
How are those Integy axle tubes? Im thinking of doing them w/ JP knuckles and stock plastic gear cases.
jamesbernatchez is offline   Reply With Quote
Old 06-21-2007, 08:55 PM   #104
Check back in with RCP. I hear they just got a HUGE shipment yesterday.
I love the fit and finish of the axle tubes and the knuckles are frikin awesome! Some of the best aluminum work I've seen. I am going to switch out the cases, to plastic, for competition. For photo shoots, I will leave the chrome. This truck is being set across country for a photo shoot in two weeks.
And...as for yellow rings............pics are coming of the new set up!
Old 06-21-2007, 09:05 PM   #105
Ok.....the standard Axial rings are yellow, as requested , and bolted over the top of the larger black rings. Haven't put all the screws back in but I think it looks pretty cool and is a bit different.
Old 06-21-2007, 09:08 PM   #106
Old 06-21-2007, 09:12 PM   #107
Tree Root?
Old 06-21-2007, 09:43 PM   #108
as far as cases go...since the integy cases are exact copies (almost) of the stock plastic ones to reduce weight maybe running half metal and half platic that would give you the strength of the metal on the half that takes the abuse but give you a little less of the weight....cracked plastic cases suck.
clarkrw3 is offline   Reply With Quote
Old 06-22-2007, 04:48 PM   #109
TEAM RCC
Tree Root?
How about Shelf Queen
Get some electronics put in this thing so we can crawl!
CRF450R is offline   Reply With Quote
Old 06-22-2007, 05:05 PM   #110
Tree Root?
Old 06-22-2007, 09:10 PM   #111
Working on it. ESC is the deciding factor.
Everything else it ready to go.
Although, it will be out of state for a while.
After it gets back, I'll be ready!!!!!!
In the mean time..........who wants to go do some 1:1 wheelin in Colorado??????
Old 06-22-2007, 09:13 PM   #112
2006 2.2 National Champ
BENDER's Avatar
*Raises hand*
BENDER is offline   Reply With Quote
Old 06-23-2007, 08:55 AM   #113
TEAM RCC
MAMBA MAX ........DONE
You know I'm down for some wheeling!
Old 06-23-2007, 09:16 AM   #114
cartronicshn's Avatar
How about the new Novak crawler system?
cartronicshn is offline   Reply With Quote
Old 06-23-2007, 09:10 PM   #115
Still haven't heard a lot of positives on it.
Old 06-24-2007, 10:36 AM   #116
Ask mg i think he has the newer one, i have one revised version, and it's very powerful, i have it on my hl with rd400 2.2 beadlocks which would put the rig at around 9- 10 lbs, and the novak motor doesn't even break a sweat , it also has the low speed control dialed in, no bogging at really slow speed also has that really fine control needed on the low end , and like i said it's got tons of instant torque plus the drag brake that holds my rig at almost 90 degrees before it flips over . So 2 Novak on a hustler would definetly be overkill IMHO. Also the newer version is supposed to have sintered rotor with lipo cutoff.
Old 06-24-2007, 10:50 AM   #117
. So 2 Novak on a huslter would definetly be overkill IMHO. .
My Hustler with 2 Crawler Systems should be running by the end of the day. I'll let you know.
Rockpiledriver is offline   Reply With Quote
Old 06-24-2007, 07:51 PM   #118
have you crawled with this thing yet i would like to see some scratchs.
1beatjeep is offline   Reply With Quote
Old 06-25-2007, 08:30 AM   #119
soon.....very soon! Got a lot on the plate right now and have not had time to finish her up.
Old 06-25-2007, 08:33 AM   #120
666
MODERHATER™
666's Avatar
Is that why your belly is so big these days?
I can't wait for you to show and compete like you said you would!
666 is offline   Reply With Quote
