Go Back   RCCrawler.com Bulletin Board > RCCrawler Brand Specific Tech > Tamiya Clod Buster
Thread: serovs mounts
Old 02-20-2004, 11:09 AM   #1
Default serovs mounts
i need to know how to mount a servo for 4ws i know how to do the front is it the same for the back like how mud cow did it?? im not to certain on this cause roght now i have only 2ws so any help would be apreciated
firstumustcrawl is offline   Reply With Quote
Old 02-21-2004, 07:19 PM   #2
Default Re: serovs mounts
mounting on the rear is the sme as the front
jmirsberger is offline   Reply With Quote
Old 02-22-2004, 02:00 AM   #3
Thats not exactly right,depending on what radio you are using and if you are using three channells to get independent rear steer.
The rear servo needs to swing the other way compared to the front other wise you will always crab it ,thats only if you use a y lead and have no indi rear steer.
If you use a three chanell you can reverse the rear servo or steer it how you want.
The mounts can be the same but can also be easier if you mount the front laying down on the axle brace and the rear standing up on the rear brace.
Russell is offline   Reply With Quote
Old 02-22-2004, 02:01 PM   #4
cool thanx
