08-30-2007, 07:45 PM | #1 |
Pebble Pounder Join Date: Dec 2005 Location: Parts Unknown (Eastern Sho, Maryland)
| Drive pin replacements?
With the TTR CVD's what can you use if you have lost (or cut down to fit drilled out hexes) the small drive pins that are retained by the rubber o-ring on the drive hex?
08-30-2007, 07:56 PM | #2 |
Rock Crawler Join Date: Feb 2006 Location: Easthampton
Cut a piece off of an old allen wrench
08-30-2007, 09:31 PM | #3 |
Quarry Creeper Join Date: Jul 2007 Location: Mac
i've had good luck with roll pins
08-30-2007, 11:01 PM | #4 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
I currently have the shank of a drill bit in one of mine.
08-30-2007, 11:18 PM | #5 |
MWRCA'er Join Date: Apr 2004 Location: Machesney Park IL
Shank of a drill bit works well. You can order rod from mcmaster if you want to get fancy. I'm sure you can also find replacements on tower, those pins are a pretty standard size.
08-30-2007, 11:27 PM | #6 |
I wanna be Dave Join Date: Aug 2006 Location: under a rock and a hard place
piano wire from any LHS works well also. In a pinch I have seen guys use a body clip
08-30-2007, 11:46 PM | #7 |
I would stick to hardened steel, plain steel just shears or bends.
08-31-2007, 05:04 AM | #8 |
thanks |
09-01-2007, 12:26 PM | #9 |
Rock Stacker Join Date: Apr 2007 Location: Columbia
