| | #1 |
| Quarry Creeper Join Date: Jan 2004 Location: NEW YORK!!!! long island
| should i narow the inside of the rim like you do the outside i did the outer rim now should i do the innner portion as well?? |
| Sponsored Links | |
| | #2 |
| bendforthebone Join Date: Feb 2004 Location: Jamul
| yes it will push more tread out out on the sidewall |
| | #3 |
| Rock Stacker Join Date: Feb 2004
| yes you should do it, it helps with sde bite making you clod a beter crawler and improving on handeling |
| | #4 |
| everythings lookin good now im almost there all in need is your opinion on this one im gunna run the super torque jr servo in it is that what most are running????? |
| | #5 |
| Rock Crawler Join Date: Feb 2004 Location: The Gay NorthWest
| is that the only up side to narrowing rims is having a side wall???? and flexxing??? |
| | #6 |
| Newbie Join Date: Jan 2004
| Hope these tips help: 1 Narrowing the inner rim pushes the tires slightly outward making track width wider for more stability 2 Narrowing the outer rim pushes the tires slightly inward making track width narrower to help get in tight places 3 Narrowing both sucks the sidewalls in to put more tread on the edge of the tires for more sidebite. it also helps to give more sidewall support to tires with very soft sidewalls when you remove the foams. |
| | #7 |
| i also nticed after doing this that my truck has about 1/4 inch more clearence under the diff |
| | #8 |
| Rock Stacker Join Date: Jan 2004 Location: Morgantown
| How did you cut your wheels? |
| | #9 | |
| Power of the Portals ![]() Join Date: Feb 2004 Location: where ever the wind fawkin blows me, tx
| | #10 |
| i used a hack saw but you cut use a dremel |
| | #11 |
| of course i messed up and cut the lip of the rim so now i gotta like rig something up lol i think it should be cool but yeh definetly becareful with a bandsaw it cuts fast lol |
| | #12 |
| I wanna be Dave Join Date: Jan 2004 Location: Flagstaff, AZ
| Hacksaw works the best, nice and slow so you wont screw up your rims! Take a file to it afterwards to clean em up, turns out great! (Just lay the rim down on its side and take a big file to it and make it flat) |
| | #13 |
| k cool thanx for all the tips |
| Thread Tools | |
| Display Modes | |
