11-08-2007, 12:53 PM | #1 |
Newbie Join Date: Sep 2007 Location: New Zealand
| My clod
Hi guys, I recently got hooked watching crawling videos, and although I've attempted a few crawlers before, and built smaller scale ones. I couldn't help myself when I saw this, it's hard to find clods over here so I jumped on this one. I had to give it a little rework, it was pretty high up for a start. It has RC4WD Bent lower links, and top links, RC4WD shock mounts. Alloy piggybacks, 12KG Servos front and rear. Independent rear steer. I haven't had a chance to test it yet, as I have to shoot to work. I need to make a link bar so I can get my front and rear upper links triangulated a little more. Chassis looks like it has been professionally cut, and it's a very sturdy chassis. I really need some new tires/wheels though. If anyone has suggestions to improve the rig, let me know! Please. |
11-08-2007, 01:28 PM | #2 |
Rock Crawler Join Date: Oct 2006 Location: England, Where the birds fly backwards.
You definately need new tires/wheels! also ae you running wheel weights? and most of all looks really good!
11-08-2007, 10:50 PM | #3 |
No weights in the wheels, I'm still waiting on a front Pinion! I have none, just a stock rear one which is installed in the rear. Anyone want to help a fella' out ? New tires/wheels are a must for sure, but paycheck is almost disappeared. Almost forgot I have to live! haha. Thanks! |
11-16-2007, 12:49 PM | #4 |
Nobody else care to comment ? Surely I've done a bunch of things wrong...
11-16-2007, 01:35 PM | #5 |
Rock Crawler Join Date: Feb 2004 Location: Michigan
I would move the upper links on the chassis more forward so it corrects the pitch on your axles. the way it sits now the motors point too far down.
11-16-2007, 02:21 PM | #6 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
Yep, longer upper links will help you out a bunch. Lifts the motor out of the way too, I've found. Also, I would stand the rear shock up more, means you have a bit more stability in steep climbs. Otherwise, looks like you're off to a good start! |
11-17-2007, 12:07 AM | #7 |
Thanks guys! I'll have a play around with the link setup and see what I can get out of it. I've adjusted the shocks a little already as well. Thanks for the help |
11-17-2007, 06:35 PM | #8 |
I joined the Band! Join Date: Nov 2007 Location: Fairmount
looks great. does the stock tires do well on the rocks? or are they too hard?
