11-09-2007, 01:32 PM | #1 |
Pebble Pounder Join Date: Jun 2007 Location: .
| rc4wd Raptor Axles
Does anyone know if the tubes and internals of the Raptor axle will fit to a Clod gearcase? When I say Internals I'm referring to the drive shafts of the axle and if it'd be able to work with the Clod gears, etc etc and if you can just bolt up the raptor axles to the Clod case. Also I'm wanting to know which Raptor axle is the one with axle tubes longer than the Clod axle tubes?
11-09-2007, 02:16 PM | #2 |
RCC Addict Join Date: Mar 2006 Location: Xxx
Do you have raptor axles? Or are you just getting info before buying? Cause if you don't have them don't waste your time and money they are just good for paper weights. I had them and were totally disappointed in them. As far as if you can use the internals , I don't believe so. |
