11-10-2007, 08:03 AM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: detroit
| 1/4 servo mounts
Loking for anybody that makes or knows of sombody that makes a mount for a clod axle that will let me use a 1/4 scale servo. Or maybe I should say a MONSTER Scale servo! I bought 2 Tower Pro 9805BB servos to give them a shot on my super build and don't see any way to mount them with out hacking the ears of then there isn't any way to mount them any way. I would also like to get an aluminum servo horn for them (in blue) if i can. I will going to my LHS today for some hardware and Axial parts and will also see what they have there but if any body here has done this before let me know what you did and how it worked out!
11-10-2007, 09:04 AM | #2 |
RCC Addict Join Date: May 2006 Location: In England, looking for the threadlock...
The 805's will go onto the clod axles. Just. Only requires some slight trimming to the axle tube (pics 4 and 5), before you can just fab a plate to bolt it all to. Make sure your steering links are up to it, the Hitec 805's can bend the ones in pic #3 in half like there's nothing there. |
11-10-2007, 11:33 AM | #3 |
Hey thanks! that is sertainly one way to do it but was wandering if that wont weeken the axle tube to much? I was thinking of a lay down type mount but it looks to me that this might be the only way but if anyone else has an idea let me know. I was also going to try to do a behind the axle steering system.
11-10-2007, 11:55 AM | #4 | |
Pebble Pounder Join Date: Mar 2007 Location: Perkasie PA & Port Norris NJ.
11-10-2007, 11:55 AM | #5 |
Turtle, could you please post some pics?
11-10-2007, 12:00 PM | #6 |
It won't sit flat, unless it's mounted over the pivot point of the steering knuckle. If you check out Double J's 'Super Goat' build thread, you can see that he did it that way. The axle tube has not been noticably weakened by this minimal trmming . |
11-10-2007, 03:12 PM | #7 |
I checked that thread out and he has a diagram of his 1/4 servo mounts on there on the last page but no diamensions. I am going to try to contact him for them and if he has any he might part with. thanks for all the input guys! |
11-10-2007, 11:03 PM | #8 | |
Quarry Creeper Join Date: Nov 2005 Location: Australia
id be happy with the set up already shown here, without going to the trouble of laydowns. | |
11-10-2007, 11:30 PM | #9 |
Providing I'm not cutting into anybodies business for sure! That is what this forum is about in it not. Were here to share info and help each other enjoy this addiction we call a hobby but not to take away from somebodies business.
11-11-2007, 12:28 AM | #10 |
Newbie Join Date: Aug 2007 Location: reno
hey jeepfreak, i just took some flat piece aluminum ans bolted them to the axles braces then braces them with a lil piece of "C" channel that i cut one angle side off and bent over, and screwed it to one of the lil screws that hold the axle tube to the housing. mine are really stron, and it doest have the chance to twist the braces at all. snappy steering
11-11-2007, 03:39 PM | #11 |
Pebble Pounder Join Date: Sep 2007 Location: Fallbrook
do 1/4 scale servo's use the same arm's as standard scale servo's?
11-11-2007, 03:42 PM | #12 |
11-11-2007, 03:48 PM | #13 |
Does anybody make Aluminum arms for them?
11-11-2007, 04:36 PM | #14 |
11-12-2007, 10:35 PM | #15 |
Pebble Pounder Join Date: Mar 2006 Location: hillsboro
Got my laydown 1/4 scale mounts from syco133. He used to have a ad in the classified section for them.
11-13-2007, 08:58 AM | #16 |
I wanna be Dave Join Date: Sep 2005 Location: R.I.P. Chip
Like this?? |
11-13-2007, 11:41 AM | #17 |
I wanna be Dave Join Date: Dec 2005 Location: between heaven and hell.
Currently I won't be able to take on any more projects for a bit, so for those of you that wanted me to build them some 1/4 mounts this is the best I could do at the moment. When I have some time I'll make a few and offer them up for sale and have a couple that can be used as BTA set ups like I used on the SUPER GOAT. When I built the 1/4 mounts I didn't take any measurements cause I'd just use the axles as a base for the size. I 1st cut a piece of metal about 1" or so wide and started by drilling a hole for the knuckle hole (i think it's called) layed it as close as i could to the gear box and bent it. I thin bent a little lip for the servo to mount next to the gear box then added a hole for it to mount to the gear box where the stock brace mounts. Then I brazed the second mount for the servo. After I did this I figured a way to make it all one piece. It kinda needs to be reversed for a BTA and then I used 1/8 solid rod for the steering links and tap (die) the ends for traxas rodends. Sorry I couldn't get better measurements but if I can get some time I'll add that to my to do list. My BTA set up. |
11-13-2007, 11:46 AM | #18 |
Also wanted to note that I didn't have to cut or trim any part of the axles for this to work. I also made some 1/4 scale mounts that stood the servos up instead of laying down. If anyone want's this set I'll let them go cheap. |
11-13-2007, 01:56 PM | #19 |
11-13-2007, 05:04 PM | #20 |
Ok... I don't have the truck together yet but I will go out and take a pic of what I have done so far and you guys can tell me if I'm barking up the wrong tree or not. I will post it up here later tonight.
