11-15-2007, 02:34 PM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: Carlisle
| run time?
for a clod what is the average run time? I was going to use 6-8 1500 elites. but if anyone knows something better please let me know. Thanks
11-16-2007, 06:00 AM | #2 |
Rock Crawler Join Date: May 2006 Location: United Kingdom,Scarborough
I am running a 8cell 1500mAh 9.6v 2/3a battery pack on my stick the pack last about 30 -40mins. I would go for a higher mAh pack. Higher the mAh longer battery life Regards james |
11-16-2007, 08:22 AM | #3 |
Pebble Pounder Join Date: Oct 2007 Location: In a House on a Hill
true, I have a 1500mah and a 4200mah, I get about an hour out of the 1500 and about an hour and a half from the 4200, real low gears in mine though, no speed what so ever, speed is what kills the most.
11-16-2007, 02:12 PM | #4 |
11-19-2007, 03:32 PM | #5 |
Rock Crawler Join Date: May 2007 Location: lacey
| what motors are you using? with 55t lathes, i got about 25mins on a 2300mah a123 pack.
11-19-2007, 03:36 PM | #6 |
integy 55t lathe's, 9tooth pinion, r2 tranny. the packs are, full six pack one is HPI Nickel Cadium the other is DTX Nickel Metal Hydride. |
11-21-2007, 12:27 PM | #7 | |
Pebble Pounder Join Date: May 2006 Location: Anaheim
Any time I doubled my MAH rating I've doubled my run time. | |
11-21-2007, 03:39 PM | #8 |
Quarry Creeper Join Date: May 2007 Location: melbourne, australia
different discharge rates one might give more punch and drains quicker |
11-21-2007, 11:01 PM | #9 |
I think the release of current does not play that much into it. I mean think about it. 1500mah=1 hour 4200mah=280% increase in capacity Yet you are claiming only a 50% increase in runtime? Crazy! You might want to check that 4200mah pack out. |
11-26-2007, 09:59 AM | #10 |
Rock Crawler Join Date: Nov 2004 Location: Driving the Troysion Stick up the BIG BOY line!
I run an 8 cell 4500 mah pack, with 65t lathes and 8t pinions, I easily get about and 90 mins to two hours.
11-26-2007, 12:10 PM | #11 |
11-27-2007, 04:44 PM | #12 |
Rock Crawler Join Date: Sep 2007 Location: 42N 88.02W
I run two 55T lathes, Rooster Crawler ESC, 6 4200 sub c's, 7 tooth pinions and I get 1.5 hr runtimes easily, there's a lot of variables with runtime and batteries though.
