12-31-2007, 03:09 PM | #41 |
Rock Crawler Join Date: Dec 2007 Location: Shreveport, La
then cut that piece off on the line that runs front to back and you end up like this: |
12-31-2007, 03:10 PM | #42 |
check back in a few minutes. as i am doing this and posting at the same time |
12-31-2007, 03:31 PM | #43 |
alright, here it is after making all the cuts on this one section AND after sanding everything down smooth including the bottom bolt hole and bumper mounts. |
12-31-2007, 03:39 PM | #44 |
As you can see there is some light shing through where i sanded down the bottom bolt and bumper mount on the bottom side of the case. well its pretty thin right there, so now is a good time to reinforce that area from the inside with jb weld. i use JB Quick, simply because its QUICK. just mix it up and fill it in. i also found that if you use a little more hardener than steel that once it dries you get a harder surface than 2 equal amounts like the directions tell you to do. dont forget to SCUFF ALL SURFACES you apply the jb weld to AND THEN CLEAN with some rubbing alcohol or something similar |
12-31-2007, 03:39 PM | #45 |
let it sit for a few minutes and its dry enough to move the parts around
12-31-2007, 03:57 PM | #46 |
now you have to make a form for the JB weld to mold to. i use masking tape. cut strips off the roll as i need them with an Xacto knife. stretch the tape tightly over the hole and try to give it somewhat of a round surface. |
12-31-2007, 03:59 PM | #47 |
lay a new batch of jb weld down onto the sticky side of the tape in the housing. A thin layer will do for this. try to stay away from the bolt holes. If you get up to close to the holes, dont worry, you can grind it down later. |
12-31-2007, 04:29 PM | #48 |
about 5-10 mintues later slowly pull the tape off |
12-31-2007, 04:30 PM | #49 |
look ma, no tape! |
12-31-2007, 04:31 PM | #50 |
now tape up the other section |
12-31-2007, 04:32 PM | #51 |
weld it up! |
12-31-2007, 04:33 PM | #52 |
tape off... dont worry bout how this looks on the outside. you'll be adding exterior layers on both of these sections. |
12-31-2007, 04:55 PM | #53 |
now mix up a bigger batch and do i thick coat on the outside. make it thick enough so you can sand it down smooth without any holes or indentions |
12-31-2007, 05:43 PM | #54 |
i used a real coarse file i had to shape sand it all down and shape it up better. dont grind it all off though |
12-31-2007, 05:45 PM | #55 |
oooooo look at the clearance |
12-31-2007, 05:48 PM | #56 |
thats all for tonight, its new years eve, i gotta get outta here. its Miller Time |
12-31-2007, 07:38 PM | #57 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
Very nice work, makes me want to try building a 2.2 clod.
12-31-2007, 11:00 PM | #58 |
I wanna be Dave Join Date: Aug 2004 Location: san jose
with all of this work how much more clearence do oyu gain.
01-01-2008, 05:47 AM | #59 |
i dunno, .......thats not the point, theres definitely more work than benefits though. its not for eveybody |
01-01-2008, 01:03 PM | #60 |
I wanna be Dave Join Date: May 2006 Location: akron
any clearance will help and that was great how to. |
