01-03-2008, 01:21 PM | #81 | |
Rock Crawler Join Date: Sep 2005 Location: IDK
Sorry , but if it works i sertainly something i would try! Good luck with it | |
01-03-2008, 01:53 PM | #82 |
Powered by Awesome Join Date: Sep 2004 Location: Parker, Colorado
i would love to see a follow up on this after some abuse... Awsome idea! Thanks for puting ideas into my head...
01-03-2008, 03:09 PM | #83 |
Rock Crawler Join Date: Dec 2007 Location: Shreveport, La
i havent tested it at all, it hasnt even been out of my house. i'm still waiting on electronics, steering, tires, and some different gearing. It's all in the mail! |
01-03-2008, 05:02 PM | #84 |
Tap it with a Screw driver or somehthing to test the new case. Better to find it's weak part now then after it's completly built.
01-03-2008, 05:35 PM | #85 |
oh, it'll pass that test for sure................hell i'll go try anyway ............i just went and beat the crap outta it with a big phillips, then the sharp edges of a small crescent. no chips or dents Last edited by cspyy; 01-03-2008 at 05:43 PM. |
01-03-2008, 05:36 PM | #86 |
rear knuckles locked out!! |
01-03-2008, 05:37 PM | #87 |
did some grinding on the front knuckles for more steering |
01-03-2008, 05:38 PM | #88 |
yes, stock axles, still no binding though |
01-03-2008, 05:41 PM | #89 |
body halfway mounted. Had to grind on the front of the chassis and stretch & push down the bug body to get it lower like i wanted. wanted it low as i could get it without hacking into the nose piece. i think it looks pretty cool |
01-03-2008, 05:42 PM | #90 |
| that picture definitely sucks |
01-03-2008, 06:55 PM | #91 |
i am thinking about mounting my battery pack right here like in the picture. there are several pros and cons about it. what do you guys think? feedback please |
01-03-2008, 07:21 PM | #92 |
Rock Crawler Join Date: Apr 2006 Location: Salem, Orcrc
if you can get a 2/3a pack made a cheapbatterypacks.com and stick on one of the front axle tubes. i wouldnt mount your battery on the bottom other wise its gonna be draged on the rocks.
01-03-2008, 07:29 PM | #93 |
yea i know what your saying but the way it is now, i will have 3 1/2" of ground clearance at the battery after putting the tires on. i figure with this pimp cane having soo much clearance, if i put the battery under it, i would still have more clearance than most shafty's. trying to not put ALL the weight on the front axle, keeping it low and a little more centered. |
01-03-2008, 08:09 PM | #94 |
heck the body still hangs lower than that battery
01-03-2008, 10:11 PM | #95 |
Rock Stacker Join Date: Jan 2006 Location: CT
:hijack on: i mounted my battery to the side of my homemade cane chassis, seems to be holding up alright for a nice centered weight distribution. I vote go for it but obviously expect some rock contact. :hijack off: Last edited by Dirty Jeepster; 01-03-2008 at 10:15 PM. |
01-03-2008, 11:21 PM | #96 |
The battery placemnt would be alright there, but then again it's going to be used as a skid plate has well. Look into a small 2 cell Lipo and run on the axle brace. That will put the weight up front and also a little lower. One more thing is that the Lipo will weigh less then half that 6 cell pack.
01-05-2008, 07:00 PM | #97 |
Pebble Pounder Join Date: Mar 2006 Location: Asheville,NC
01-05-2008, 07:23 PM | #98 |
Newbie Join Date: Jul 2007 Location: Avondale,AZ
youre rig is comming along great , cant wait till its done . and tested .we all waiting.
01-05-2008, 08:06 PM | #99 |
thanks guys got my Hands BRos. BTA in yesterday and put it on, |
01-05-2008, 08:09 PM | #100 |
its a REALLY nice setup, that tieod plate is STOUT. only thing weird was in the directions it says a servo arm at 8mm long is best with this. That cant be right, 8mm would never work. had to do a little grinding on the servo bracket to fit around the jp axle tubes |
