01-07-2008, 10:37 AM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: Carlisle
| Anyone Using These?
just wondering if anyone is using the thunder tech aggressor bta steering and if so what do you think? and what are they made out of? http://www.tcscrawlers.com/Thunder-T...0-p-16253.html |
01-07-2008, 10:54 AM | #2 |
RCC Addict Join Date: Apr 2006 Location: Brighton
Those are Carbon Fiber...haven't used them, but I know a couple guys that have. Or just make your own, I used a setup similar to Dezfan and EeePee. Use the stock clod axle stay to mount a couple of servo mounts to and mount the servo backwards. Flip the knuckles backward and put everthing together, it works really good and you probably already have the parts needed for it. At the worst you'd need 4 rodends, some allthread (8-32) and a 1-1.5 inch servo arm. I used Maxx rodends and threaded some steel or aluminum 1/4 rod. Delrin rod works nice, too. Does "behind the axles" limit artic? Last edited by DeaDShorT; 01-07-2008 at 11:00 AM. |
01-07-2008, 07:00 PM | #3 |
I wanna be Dave Join Date: Oct 2005 Location: Columbia TN
I have used one, they work ok, but they are not neccissary for a super truck.
01-07-2008, 07:07 PM | #4 | |
Rock Crawler Join Date: Apr 2007 Location: APPLE VALLEY,CALIFORNIA
01-07-2008, 07:16 PM | #5 |
They limit the steering more that a conventional forward facing steering.
01-07-2008, 11:04 PM | #6 |
01-07-2008, 11:23 PM | #7 |
RCC Addict Join Date: Mar 2006 Location: Xxx
You could get away with it in the front like "normal" But if you compete you might get hindered by it being your first thing to hit while trying to get up and over your obstacle. If you have the ability to try both THAT is what I would suggest. Then you can make your own decision and run with that . |
01-08-2008, 06:11 AM | #8 |
Pebble Pounder Join Date: Sep 2005 Location: Columbus
If you want to use a BTA system you could go with the J&M Customs BTA Kit. It doesnt limit the steering like the Thundertech Racing one. Plus the J&M one is cheeper... Thats just my 2 cents.
01-08-2008, 09:11 AM | #9 |
01-08-2008, 09:55 AM | #10 |
I would just wait for the J&M Customs BTA Kit to be made again. I like it alot better then the Thundertech one.
01-08-2008, 11:21 AM | #11 |
Running it in the front has never hindered me.
01-08-2008, 12:05 PM | #12 |
01-08-2008, 12:32 PM | #13 |
heres what I came up with. with all the more steering i can get out of the stock knuckles and tubes this will work great. |
01-08-2008, 02:38 PM | #14 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
Here's a great thread for different home made Behind the Axle setups: Does "behind the axles" limit artic? |
