Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Tamiya CR-01
Thread: cr01 set up
Old 04-30-2008, 02:38 PM   #1
vipxj's Avatar
Default cr01 set up
Hi
just started building mine,whats everbody using for motor,pinion ,and what about cutting the foams.I didnt fit the tortion bars other than that i might run it stock standard and then change motor etc.Tamiya have done a great kit.
vipxj is offline   Reply With Quote
Old 04-30-2008, 09:20 PM   #2
I am running it pretty stock however i didn't use the torsion bars. Motor is an Atlas 50T with the stock pinion but I think I will change it down some!
genki is offline   Reply With Quote
Old 04-30-2008, 09:35 PM   #3
vipxj's Avatar
I think i will fit a 55t with the standard pinion ,other than that stock like everybody else.
