Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Tamiya CR-01
Thread: CR-01 at RCP??
Old 04-30-2008, 02:47 PM   #1
Default CR-01 at RCP??
In stock and I have mine on the way to me....
I can't wait!!!
It will be up later today on the site.
FrankyRizzo is offline   Reply With Quote
Old 05-09-2008, 02:31 AM   #2
Got mine together. Painted it up tonight.
For now here are some pics of it earlier today unpainted.
Old 05-09-2008, 08:36 AM   #3
WOW looks like the axles drop out pretty nicely, where did you get those rings franky
TREE68 is offline   Reply With Quote
Old 05-09-2008, 12:32 PM   #4
Those are Vanquish Revolver beadlock wheels. The rings are the stock one that come with those wheels.
bustedcrawler is offline   Reply With Quote
Old 05-09-2008, 01:19 PM   #5
vipxj's Avatar
Those rims and tires look so good,what color are you going to paint it.
vipxj is offline   Reply With Quote
Old 05-09-2008, 01:45 PM   #6
oh ya, seen some last week. the ones with the weights. SICK
Old 05-09-2008, 02:53 PM   #7
Rockpiledriver's Avatar
The're here tree come buy tonight and get a set they won't last long.
https://rcpcrawlers.com/home.php?cat=24
Rockpiledriver is offline   Reply With Quote
Old 05-09-2008, 04:59 PM   #8
I got it painted up last night. I am really digging this thing. I will have it driving this weekend.
Old 05-09-2008, 05:01 PM   #9
I omitted the sway bar dealy when I built it. I am going to run some thicker oil in the shocks though. I will check it out once it is drivable.
Old 05-09-2008, 07:10 PM   #10
Damnit. I want one. Looks great!
Col_Sanders is offline   Reply With Quote
Old 05-11-2008, 10:56 AM   #11
Default Update
After building it without the sway bar dealys and the stock oil it had torque twist and was way to waggly. I decided to install the thicker wire in the rear and swap out the oil for 90wt. Much bigger difference and the handling is way better.
Old 05-11-2008, 11:06 AM   #12
TEAM MODERATOR
EeePee's Avatar
Yeap, pretty sure you gotta run the sway bar dealies.
I put the stiffer springs in back too.
Good paint job FR!
EeePee is online now   Reply With Quote
Old 05-11-2008, 11:07 AM   #13
Paypal....arghhhh!!
cartronicshn's Avatar
Same problem here, i think it has a lot to do with the weight on the wheels also, i did the same as you initially and even went with the 2 hole piston on the shocks and ended with severe torque twist.
cartronicshn is offline   Reply With Quote
Old 05-11-2008, 12:06 PM   #14
Good paint job FR!
I ran mine like the book states.
I am also running a 3600 lipo in the tray so I think I have less weight up top also.
