| | #1 |
| Quarry Creeper Join Date: Oct 2006 Location: Japan
| I have already seen a few twisted shafts from other members here and today found the same issue with my own CR-01. I have the Tamiya replacement but was wondering if anyone has found a stronger solution than making more twisted shafts?? |
| Sponsored Links | |
| | #2 | |
| RCC Addict Join Date: Jan 2008 Location: www.rccrawler.com
I mean like maybe if you epoxy them so they don't pull apart ... | |
| | #3 |
| Like epoxy them so they no longer slide? Not exactly what I had in mind! |
| | #4 |
| Paypal....arghhhh!! ![]() Join Date: May 2006 Location: HONDURAS...ROCK HEAVEN
| | #5 |
| Thanks for the help...appreciate the effort ;) |
| | #6 |
| Rock Crawler ![]() Join Date: Oct 2007 Location: Auburn
| Pt# 1651 mid length 1951 is the long (most common used)You can shorten these. 4628X is the Ujoints for those driveshafts. Here are the Traxxas part numbers for the Pede driveshafts. I will taking these with me to the MSD meet in 2 weeks for backup. I have a slight twist in mine so far. I run 3s and Flightpower packs in all of my trucks Scale and Comp. |
| | #7 |
| Thanks for the tips. Got it sorted out I think. I used the Traxxas Half Shafts #1951 and replaced the Tamiya plastic Yokes with the Traxxas Hardened steel ones #4628X. I had to cut the "lip" of the Yoke to get it to fit better but all seems good. I also need to do the front which will require the shafts to be cut down a bit! There may be an alternative way but I used what I had ;) |
| | #8 |
| Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
| Quote: |
| | #9 |
| Rock Crawler Join Date: May 2007 Location: Valdosta
| RC4WD probably produce a Punisher shaft that will fit. Check their site for your exact length needed. I know they work well with my Tamiya TLT. |
| | #10 |
| Quarry Creeper Join Date: May 2006 Location: Volcano, Hawaii
| | #11 |
| Newbie Join Date: Jun 2007 Location: Chicago
| I cant believe we are using this same Traxxas upgrade on a new crawler truck.Tamiya built this thing to crawl,but the Tamiya parts cant handle it? |
| | #12 |
| I am pretty sure Tamiya designed it for the entry level scale/crawler enthusiast in mind, if you want to go hardcore crawling you have to mod parts, the shafts for one |
| | #13 |
| I agree with that,the easiest weak link to fix is the shafts,and the traxxas parts are cheap.This truck will be a trail truck for me,so the original shafts should last awhile,I hope. |
| | #14 |
| I should also note that it's up to the user to say when to stop |
| | #15 |
| Pebble Pounder ![]() Join Date: Jan 2005 Location: Mission, B.C.
| For all you guys switching up to stampede shafts I have always found the Jato shafts to be a little stronger without making the jump up to the Maxx shafts, and I think the diameter looks a little more scale. |
| | #16 |
| | #17 |
| Quarry Creeper Join Date: Sep 2007 Location: New Zealand
| Will the hilux hilift ones work ? Just a thought |
| | #18 |
| For now this seems to be working out and it is a simple fix with parts that are easily accessable! |
| | #19 |
| | #20 |
| Thread Tools | |
| Display Modes | |
