Go Back   RCCrawler.com Bulletin Board > Scale Rigs Brand Specific Tech > Tamiya CR-01
Thread: Pinion shims
Old 05-13-2008, 03:15 PM   #1
Default Pinion shims
According to the instruction you only need to put 1 on the outside of the axle housing, mine had alot of free play,I ended up putting .78mm on one and .90mm, the .9 seems a bit tight,there sure is alot of free play on the bearings.
Anyone just put one? or two? or 3?
Joat is offline   Reply With Quote
Old 05-14-2008, 10:35 PM   #2
i just added what the instructions called for. i put the axle together and it is a little tight but im sure that will break in.
twisted is offline   Reply With Quote
Old 05-14-2008, 11:13 PM   #3
I did not like how much movement was there with one shim -not including bearing freeplay.
