| | #1 |
| RCC Addict Join Date: Sep 2004
| ok, 1st guys i apologize as i know i read it some where and after reading countless pages for the last hour i was wonder if someone new exactly where it was talked about when jia (i think) spaced the upper front links. im getting towards the end of my build and i want to make sure i do every thing everyone has found that makes the tlc work better. thanks for the help. |
| Sponsored Links | |
| | #2 | |
| Rock Crawler Join Date: Apr 2008 Location: On the Snap on truck
http://rcdriver.com/forums/showthread.php?t=1515&page=9 | |
| | #3 |
| yea thats about the cantilever/shock position change.this is the upper front 4 link bars. i thought it was in that article but i didn't find it. i don't know....lol |
| | #4 | |
http://rcdriver.com/forums/showthread.php?t=1740 Oh and I also used part x-3 under the front upper links and moved the link frame side to the upper /foward most hole on the side frame, much better, the link does not hit the stock motor, unless you yank down on the front axle ,under normal suspension sag, you get about 2mm clearence. Last edited by Joat; 05-15-2008 at 02:41 AM. | |
| | #5 |
| Paypal....arghhhh!! ![]() Join Date: May 2006 Location: HONDURAS...ROCK HEAVEN
| | #6 |
| thanks JOAT, that was the page. this is the paragraph i was looking for. the front upper links bind up if installed according to directions, they are fairly short and when in the V shape it puts some stress on the links. i used a longer screw where they mount to the chassis and used an extra spacer to remove the stress and they pivot much freer. Oddly enough, the rears worked fine where they were - i know Jason ran into some binding, but mine were perfect - it was the front that was giving me fits. thanks again ! |
| Thread Tools | |
| Display Modes | |
