| | #1 |
| Quarry Creeper Join Date: Jun 2007 Location: bay area
| what are you all doing? 1,2 or 3 piston? What weight oil? Etc... |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Aug 2005 Location: newport
| stock is 1 hole piston and I went with 30wt silicone oil. I think I want to try 50 though to slow it down some. |
| | #3 |
| Paypal....arghhhh!! ![]() Join Date: May 2006 Location: HONDURAS...ROCK HEAVEN
| Agree with william here, i tried the 2 hole setup and had almost no flow control on the shock, so i went back to the 1 hole piston and 90wt oil on the three shocks and 100wt on the torque twist side |
| | #4 |
| TEAM MODERATOR ![]() Join Date: Jul 2004 Location: Chit Chat
| Stock pistons and 40 weight oil in the back shocks, stock oil in the front shocks. I like some shock action so I can have some suspension action goofin around in the woods. |
| | #5 |
| ok guys sounds good, but as you know im running the unimog body and have some extrea wieght so what should i do? |
| | #6 |
| Is it all floppy? No matter the answer, I'd just use the stock piston, and tune with oil weight. If it's floppy, go a little thicker with the oil. Still floppy, go a little thicker. When it gets bouncy (bouncier really as it's already bouncy) driving around then you've gone too thick with the oil, and should consider a stiffer spring. |
| | #7 |
| thanks |
| | #8 |
| Newbie Join Date: May 2008 Location: San Jose
| I went 2 hole piston and stock shock oil on all four. On the rear I moved the shock link to the #1 hole (top left) on the cantalever. That gave full articulation to the front and saves the rear shocks from bottoming out. While keeping all the links in stock set up. |
| | #9 |
| Rock Stacker Join Date: Apr 2008 Location: Orange Park
| 1 hole piston, 60 wt oil, no sway bars. |
| | #10 |
| well i went i hole with 80 wt and it worked great for my build |
| Thread Tools | |
| Display Modes | |
