06-04-2008, 05:12 PM | #1 |
Newbie Join Date: May 2008 Location: Hampton
| "tie rod" question
The CR-01 instructions clearly state 51mm from link to link. The one that came with my kit is 90mm long, and the non threaded section is 67mm long. Did I get the wrong part? Is this a misprint in the instructions? |
06-04-2008, 05:27 PM | #2 |
Quarry Creeper Join Date: May 2008 Location: Colorado Springs
There are a few tie rods in the kit. Make sure you pulled the right one from the right bag.
06-04-2008, 06:24 PM | #3 |
all the others are much shorter than 51mm
06-04-2008, 06:27 PM | #4 |
I just lined up the pictures with the parts. Try that? |
06-04-2008, 06:36 PM | #5 |
Yeah nothing in the parts pack is matching up to the 51mm rod on page 9 step 13. DOHH!!!!! It just isn't in the kit. I see now on page 15 the one I thought was the front tie rod piece actually locks up the rear steering. The front end tie rod just isn't in my kit. Last edited by green73; 06-04-2008 at 06:45 PM. |
06-04-2008, 09:50 PM | #6 |
The part should have been in bag b. Double check that you didn't throw it out when throwing out the bag. The actual shaft should measure 65mm. You should have 2 of these, if not, than you just may be missing it.
06-04-2008, 09:55 PM | #7 |
| I left the pack with this tie rod in another room of the house. I had it the whole time. |
06-05-2008, 07:45 AM | #8 |
06-05-2008, 11:40 AM | #9 |
Moral of my story...... don't drink and build. That's near Blasphemy, I can't adhere to that! |
06-05-2008, 12:20 PM | #10 |
Quarry Creeper Join Date: Aug 2005 Location: newport
that manual makes a great beer coaster. The problem I have when drinking and building is remembering to NOT use the dremel to open beers. Sounds fun, but cleanup is... |
06-06-2008, 02:33 PM | #11 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
The Old Dremel Beer Trick. Ah Ha At Least Im Not The Only One.
